Continuing problems after repairs? - Mustang Evolution
Old 05-01-2014, 11:19 PM   #1
NFloris_05's Avatar
So I changed my spark plugs, and the day after the car ran like crap (I'm thinking it's cause I scraped that night after I changed my plugs quite hard). But after that I changed my oil, gas and air filters, which fixed the problem for a day then the problems came back (problems are: CEL, shaking, no low end torque or high end torque, the idle jumps between 250 RPM and 1000 RPM excessively and the car makes a loud rumble noise when I go WOT and it goes no where, it just makes a really loud roar with some choking noises ). I plugged in a tuner and it said plugs 6-8 weren't tight, so I tightened them down, and double checked the other ones, then the problems came back a day later. Someone suggested I check my injectors and my coil packs, which I did, and they were all fine except one injector, which I replaced. Problems went away and came back again a day later. I've replaced all fluids, all filters and pretty much everything I could think of and things that have been suggested, but to no avail. Could it be my catalytic converter being broken after scraping hard? Or is my car on it's last breath?
2005 Mustang GT 5 speed manual
NFloris_05 is offline   Reply With Quote
Old 05-01-2014, 11:38 PM   #2
Aggiesrok's Avatar
Check the codes again. You should be getting several codes.
Old 05-01-2014, 11:39 PM   #3
NFloris_05's Avatar
I would need the tuner for that correct? The tuner I used before belonged to a friend of my dad's. but I'll try and see if I can get a hold of him again.
Old 05-02-2014, 07:37 AM   #4
Aggiesrok's Avatar
Autozone will run a code reader on your car free. Just write down all the codes and look them up. Other parts stores may do it also.
Still jerks after repairs to fuel pump and solenoid Skinhorse 2005-2010 V6 Mustang 5 11-10-2013 05:04 PM
Car problems after repairs at dealership 2013Coyote5.0 2011-2014 Mustang GT 4 07-15-2013 08:30 AM
Advice on body repairs after an accident 99svtcobrainga SVT Mustang 2 11-30-2011 06:55 AM
Need a good body shop for collision repairs Mercedez L. Regional Mustang Discussion 1 06-04-2008 10:00 PM
Xbox 360 Repairs Black95GT The Bar 17 10-28-2007 10:34 PM
02:41 AM
