Idle dropping - Mustang Evolution
Old 05-25-2014, 01:16 PM   #1
C_Dailey95's Avatar
Idle dropping
So, I got a used tuner unlocked and everything, no tunes from AM or Steeda or anyone yet as I can afford it yet, but I found out you can change the rev limiter and such with out having to have custom tunes so I tried it, for some reason my "driving limiter" would cut me off at 2600rpm which is what I set the neutral limiter too, so I did restore to stock, it runs normal but now when I stop, my idle drops to 500 and raises back up to 1k and it will just go up and down repeatedly. Is this normal when using tunes for the first time? Will it go back to normal after driving for a bit? If possible could someone send me a tune file for 06 gt with off road pipe as I'm desperate for a tune. Any help would be great.
C_Dailey95 is offline   Reply With Quote
Old 05-25-2014, 08:06 PM   #2
C_Dailey95's Avatar
Nobody? Do the strategy tunes even work on the manual transmission? I googled it and seeing everything about auto.
Old 05-25-2014, 08:39 PM   #3
Blogger
99ford's Avatar
Idle dropping
I don't think that is normal at least I've never heard anyone say that.
I wish I knew more, but I'm not the most savvy person when it comes to engine tunes. Give me front brakes, over heating, and misc. engine codes for 500 please. Haha
Old 05-25-2014, 10:12 PM   #4
08AlloyGT's Avatar
What kind of tuner is it? I bought a SCT tuner shortly after buying my car. The "canned" tunes pre-loaded on the tuner worked flawlessly. I upgraded to Bama tunes for life after I started adding mods to my car.
08AlloyGT is offline   Reply With Quote
Old 05-27-2014, 01:34 AM   #5
wiatt93's Avatar
When I put a tune on mine I was having the same issue and sometimes when I slowed down or stopped it would stall from idling so low. So after looking at a lot of forums I took off the throttle body, CAI, and mass air flow sensor and cleaned them all. I put them back on and everything was fixed and the car has never run better.
wiatt93 is offline   Reply With Quote
Old 05-27-2014, 10:00 PM   #6
C_Dailey95's Avatar
Sct, I'm trying the strategy tune, which I read is the canned tunes?
Old 05-27-2014, 10:02 PM   #7
C_Dailey95's Avatar
I've seen that, I'm not to sure how to clean them though? I've also read that you have to do a idle relearn process and that'll help
Old 05-27-2014, 10:55 PM   #8
wiatt93's Avatar
You do have to do the idle relearn which I did but it didnt help at all. Thats when I cleaned everything and it worked. You can watch videos on youtube of how to do it and its pretty easy. You just have to make sure you use cleaners that are made for what your cleaning. So if the idle relearn doesnt work then I would clean everything.
Old 05-27-2014, 11:09 PM   #9
C_Dailey95's Avatar
Ahh alright cool, I'll check it out!
Dropping in a 2000 gt motor Blackedout Pre-2005 V6 Mustang 20 02-07-2012 09:48 PM
dropping tank on 99 GT 1ijack 1996-2004 Mustang GT 1 09-11-2010 07:23 AM
Window Control Panel in Door - Dropping/Moving SarasotaTim 1996-2004 Mustang GT 6 07-23-2010 07:49 AM
Deadly Bird Dropping: MarkuzLS1 Mustang Audio & Video 15 05-24-2006 07:39 AM
holy jaw dropping fox!! Zim The Bar 19 10-29-2005 08:04 PM
04:30 PM
