Engine in 05 mustang gt shakes - Mustang Evolution
Old 05-30-2014, 07:18 PM   #1
Jjhosey's Avatar
Hi I have a 05 mustang gt and sometimes driving on the freeway with the AC on the engine shakes and sputters like its going to brake down and when I turn the AC of it still does it for a little bit. Can anyone help my dad is ready to sell it it's way to bad *** to sell. And the only mod is flow master 40s mufflers nd k&n intake
Jjhosey is offline   Reply With Quote
Old 05-30-2014, 08:12 PM   #2
Hellish Horse's Avatar
Take a look at the Harmonic Balancer & see if it wobbles while the motor is running. If it is...That's your problem. You can also double check the balancer by looking to see if the thin rubber piece is starting to come out anywhere. In case you dont know what the Harmonic Balancer is ... It's the thing right behind the lowest pulley on the front of the engine. Easy to see with a flashlight if you look under the front of the car. But don't do it running...lol.
Hellish Horse is offline   Reply With Quote
Old 05-30-2014, 08:22 PM   #3
The Balancer wont make it sputter tho...just shake. It's probably a dirty or bad sensor.
Did he clean his MAF Sensor ? Check his IAC sensor ? Sputtering sounds like it could be one of those sensors. Clean the MAF Sensor with paint thinner. I use a little cap off something, pour a little thinner in it & rest the sensor across the cap with just the wires in the thinner. Don't worry...Thinner wont melt plastic. Leave it over night. Next day...take a Q-Tip & Rubbing Alcohol & wipe off the wires gently. Re-Install it & it's like new again.
Old 05-30-2014, 08:38 PM   #4
Jjhosey's Avatar
Where are thos located at cuz I think it might have something to do with the AC compreser
Old 05-30-2014, 08:53 PM   #5
The MAF Sensor is usually on the intake Tube that connects to your Air Filter. Different years have the sensors in different places. Just U-Tube "How To Change the MAF Sensor on an 05 Mustang" or IAC Sensor. It will show you where it's at & how to do it.
Old 05-30-2014, 08:59 PM   #6
Jjhosey's Avatar
Ok thanks so I just stop thinking the AC is doing it?
Old 05-30-2014, 09:03 PM   #7
Does the A/C blow cold ? If it is I doubt it's the compressor. Car run hot at all or normal?
If it does...Try replacing your Water Temperature Sending sensor. They're about $10.
My car ran hot & I changed out everything...Radiator, Hoses, Water Pump, etc. & it didn't help & it ended up being the cheapest part...the sensor. Cost $7 on Ebay & my problem was solved.
It seems most the time it's a sensor or vacum leak somewhere causing the problem. If you want to see if it's a Vaccum leak take the Air Line off your Brake Master Cylinder & Blow heavy smoke thru it...like cigar smoke. The smoke will come out where ever you have a leak.
Old 05-30-2014, 09:23 PM   #8
Jjhosey's Avatar
Ok do u know of anything els I can try if it doesn't work?
Car shakes after oil change on a 1966 Mustang? Vaiveahtoish Classic Mustangs 2 12-11-2011 04:16 PM
68 302 shakes badly at idle after T5 swap TEvans720 1979-1995 Mustang GT 6 05-14-2010 06:33 PM
2000 v6 shakes when i fully stop - help! CHILE10_STANG Pre-2005 V6 Mustang 7 06-25-2009 11:49 AM
Engine Swap/ Engine Shakes too_cool_mitch Pre-2005 V6 Mustang 2 02-28-2006 02:01 PM
mustang engine kinda shakes?! mexor The Bar 29 09-17-2003 09:01 PM
01:43 AM
