Wheel bearing hub - Mustang Evolution
Old 06-04-2014, 05:17 PM   #1
MasonStacks's Avatar
Wheel bearing hub
Is the front wheel baring hub on a 2006 mustang gt the same as the back or no?
MasonStacks is offline   Reply With Quote
Old 06-07-2014, 12:41 PM   #2
Rogue Slider's Avatar
I had mine done about 2 weeks ago and they were the same.
Rogue Slider is offline   Reply With Quote
Old 06-07-2014, 08:28 PM   #3
Abominable Mustang
WhoDat's Avatar
Region: Alaska
No. The front are different from the rear. The front bearings are integrated into the wheel hub. The rear hub is part of the axleshaft, whereas the bearing is a separate piece found in the axle tube once the hub/axleshaft is pulled.
Sent from the future.
2012 Kona Blue 3.7L V6:
Old 06-07-2014, 10:56 PM   #4
The bearings and lug bolts were one unit on my car.
Old 06-08-2014, 02:37 AM   #5
Abominable Mustang
WhoDat's Avatar
Region: Alaska
On the front, yes. The rear is a different story
Old 06-08-2014, 05:09 AM   #6
Yeah my bad I was thinking left and right not rear.
Wheel Hub Replacement Slow4V 1996-2004 Mustang GT 13 03-20-2014 07:51 PM
Replace wheel bearing/hub? FORDuhl6 2011-2014 Mustang GT 10 02-17-2013 01:02 PM
Pinion Bearing or Wheel Bearing? SCCofSV 2005-2010 V6 Mustang 0 09-30-2012 02:43 PM
Hub/wheel bearing 02PONY 2005-2010 Mustang GT 6 04-09-2012 12:51 PM
need to know the hub assembly part# Horse Pre-2005 V6 Mustang 0 07-20-2004 09:32 AM
10:23 AM
