06 GT Spark plugs - Mustang Evolution
Old 06-22-2014, 03:05 PM   #1
LuvStangs's Avatar
06 GT Spark plugs
Has anyone changed the plugs on there 4.6 ? I'm understanding it isn't easy and there's a chance to snap a plug. What the hells the deal ?
LuvStangs is offline   Reply With Quote
Old 06-22-2014, 05:32 PM   #2
GTgorilla's Avatar
I sprayed a little WD-40 down in there for each plug. Waited an hour and then slowly broke the torque on each one. I used a spark plug removal tool I got on eBay for $100. Made things a lot easier. The number for it on there is 291162131029. Good luck Click image for larger version
Name:	ImageUploadedByMustang Evolution1403479878.907047.jpg
GTgorilla is offline   Reply With Quote
Old 06-23-2014, 08:22 AM   #3
Sea foam deep creep! My car had 82,000 miles when I did mine and didn't break a single plug.
Sent from my XT1030 using Mustang Evolution mobile app
Baker3 is offline   Reply With Quote
Old 06-25-2014, 08:40 PM   #4
fwalck's Avatar
Just take your time and go slow if you get a tight one soak it with your choice of penetrating oil and do yourself a face and but the 1 piece plugs they are alot more money but they won't break apart like the one that are in your car now.
fwalck is offline   Reply With Quote
Old 06-29-2014, 06:42 PM   #5
84000 miles on mine. Did them this weekend and they all came out fine. I had bought the Lisle tool to remove the broke plugs and didn't even need it! Popped them loose about a 1/4 turn and soaked them in PB Blaster for an hour. Make sure the engine is cold.
gregthomas is offline   Reply With Quote
Old 07-05-2014, 08:40 AM   #6
cmegnin1's Avatar
I bought the Ford OEM Motorcraft replacement plugs from AM and hope they go in with no problem. I believe the replacement ones are one piece as opposed to what was in the car from factory.
Old 07-05-2014, 10:09 AM   #7
Aggiesrok's Avatar
I don't think you can buy 2 piece plugs anymore, unless it was some old stock.
Spark plugs and spark plug wires??? Moyhuerta 1979-1995 Mustang GT 11 12-05-2012 08:42 AM
No spark in the spark plugs 94GTpony 1979-1995 Mustang GT 7 10-30-2012 01:20 PM
E3 Spark Plugs Diamond Fire - Spark Plug gonzo56 2005-2010 V6 Mustang 6 09-28-2011 09:45 AM
Problem with gt40p spark plugs want some good spark plugs but most wont fit?? Justbust1n 1979-1995 Mustang GT 6 03-01-2011 03:20 PM
Spark Plugs Stang01 Pre-2005 V6 Mustang 19 07-18-2003 04:55 PM
04:24 PM
