Transmission solenoid bad? (I need serious HELP!) - Mustang Evolution
Old 06-24-2014, 04:39 PM   #1
I have an 06 GT Auto,after I changed my transmission filter and fluid (not a flush),my car started jerking. What happens is : I will come to a stop at a light,when I get ready to go,I take my foot off the brake but the car doe not move,I rev it once a little,nothing,twice....nothing then a split second later it jerks hard into gear,the wheels chirp!!
At first it did it when it was cold only,now,it does it every other day anytime. It seems to be getting a little worse now because it will hesitate sometimes when I turn at a corner and accelerate. I've changed the fluid again and the filter,I even tried the transmission slip by Lucas but no change...
Someone told me it could the TCC solenoid?? Any ideas?? At this point I will just drive it until it breaks because no one knows for sure and I'm not spending anymore money on guesses!
Thanks guys....
Bluerings is offline   Reply With Quote
Old 06-24-2014, 06:31 PM   #2
G3ARH3AD's Avatar
In ur car there it should b a 5r55s not my fav trans but owell lol, check ur fluid and make sure its full should b hot and running in neutral n steady pour from the fill hole on the drain plug t30, if it is full... Let it get warm and go from park to drive wait then go to reverse, try going back and forth from reverse to drive does it slam into gear or bump kinda hard if yes then its ur electronic solenoid body is bad happens to 8/10 5r55s in explorers and mustangs usually between 60-100k if ur having shifting probs while actually driving in higher gears or slamming between shift the its more then likely the planetary coming apart
G3ARH3AD is offline   Reply With Quote
Old 06-26-2014, 09:32 AM   #3
08Mustang's Avatar
I've got a V6 auto but mine does the same thing but only in cold weather as well
08Mustang is offline   Reply With Quote
Old 06-26-2014, 11:00 AM   #4
Ok so I looked up the solenoid for the transmission,I found the transmission solenoid as it's called and a TCC (torque Converter Clutch solenoid). So,are there 2 different ones or it's the same thing?? If there are different,which one is responsible for my problem??
Old 06-26-2014, 08:27 PM   #5
G3ARH3AD's Avatar
Electronic solenoid body is like a black pack inside the pan it actually is many solenoid in a pack..not sure if the tcc is in there or not posibly
Starter solenoid or starter lost need some help Muller 1979-1995 Mustang GT 7 09-03-2013 08:14 AM
Serious Problems Need Serious Help Red Stallion 11 2011-2014 V6 Mustang 18 08-02-2012 06:30 PM
need serious help killrocker52 2011-2014 V6 Mustang 8 06-11-2012 05:27 AM
soo many questions need serious help for my decision 98gtdriver 1996-2004 Mustang GT 9 05-28-2011 11:44 PM
need help with a serious issue Kyle The Bar 13 04-22-2005 07:48 PM
07:43 AM
