Problems filling up with fuel 2006 gt - Mustang Evolution
Old 06-24-2014, 07:49 PM   #1
regattabluefox's Avatar
Think there's something wrong with the filler neck. When the tank gets half full I have to sit there and basically force feed it fuel till it's within range of what I think it needs. Problem with that is I was on the phone today and wasn't paying attention and ended up spillin everywhere. Anyone else have this problem?
regattabluefox is offline   Reply With Quote
Old 06-24-2014, 07:54 PM   #2
Blogger
99ford's Avatar
Yeah it's a pretty common problem for 05-09's to have
Old 06-24-2014, 07:55 PM   #3
What do you recommend. New filler neck?
Old 06-25-2014, 09:10 PM   #4
Blogger
99ford's Avatar
Let me find the TSB, knock on wood, I haven't had the issue in a while.
Old 06-27-2014, 04:41 PM   #5
Any luck yet?
Old 06-28-2014, 08:43 AM   #6
C_Dailey95's Avatar
Try turning the nozzle 90 degrees. That used to work for me
C_Dailey95 is offline   Reply With Quote
Old 07-02-2014, 01:08 PM   #7
Haha cool thank you. Did you ever end up getting it fixed? I looked at the filler neck and it looks a little chinsey. Like fuel wouldn't flow through it very easily
Old 07-02-2014, 08:17 PM   #8
C_Dailey95's Avatar
It hasn't done it to me in a while. So not to sure what happened hahaa
Old 07-03-2014, 04:13 AM   #9
Last time I checked, you need to disconnect a fill sensor near the rear driver side right around the gas tank underneath the chassis. There is a sensor built into the gas pump to stop from overfilling so no worries with that. Unless it is a really old pump, then you should probably write your congressman. This takes care of said problem.
draxxus131 is offline   Reply With Quote
Problem filling car with fuel tjpfab 2005-2010 V6 Mustang 18 07-06-2014 12:37 PM
problems filling up !! billygodfree 2005-2010 Mustang GT 35 04-29-2013 03:15 PM
help-filling diff, getting aggravated..... rinfield2004 SVT Mustang 15 12-05-2011 10:36 AM
Fuel Filling Problems on 67 Mustang jmbalch Classic Mustangs 2 06-22-2011 01:29 PM
Start Filling Out Your Garage Today! Brent ME Site Help & Announcements 31 09-05-2010 11:30 PM
10:20 PM
