Disconnected battery, TPM fault? - Mustang Evolution
Old 07-04-2014, 04:24 PM   #1
Cbird's Avatar
Region: Iowa
Was running a power wire back to the trunk for subs and when I reconnected the battery I now get a "Tire Pressure Monitor Fault" message.
Could it be as simple as I need more air in the tires? How come it didn't go off earlier when I was driving around though?
Cbird is offline   Reply With Quote
Old 07-04-2014, 06:22 PM   #2
LeviG2010's Avatar
I'd say check the tire pressure. Maybe you picked up a slow leak.
2010 Mustang GT steeda CAI, steeda underdrive pulleys, mangapack catback, kooks long tubes w/ hiflo cats, accel coils, FRPP throttle body
The driver doesn't pick the car. The car picks the driver.
LeviG2010 is offline   Reply With Quote
Old 07-04-2014, 07:38 PM   #3
NewMtang's Avatar
Have you tried to reset your sensors?
Old 07-04-2014, 10:07 PM   #4
Cbird's Avatar
Region: Iowa
Hey guys.
My tires are all at 29 PSI, which is good because they are all leaking at the same rate and that means they are in-fact probably low enough to trigger the TPM system (does it trigger at below 30? Just curious when it would trigger the warning) but is "Tire Pressure Monitor Fault" the message you get when you're low? I figured it would be like "Driver side Front tire low" or something cool like that... lol
Maybe reseting the cars computer by unplugging the battery just reset the whole system and now she's good to go?
I'll fill them up with air tomorrow and see if it was just a fluke.
Old 07-05-2014, 06:39 PM   #5
Cbird's Avatar
Region: Iowa
Well, I started my car today and the error didnt show up. Filled up the tires and away I went. Guess it was just a fluke.
When should the warning normally come on? what PSI?
Old 07-05-2014, 07:19 PM   #6
JoeyM91's Avatar
You didn't accidentally splice into the incorrect wire when you ran the wiring did you? On mine the TPMS goes off under about 25 PSI, might be slightly different for your generation, but I doubt it.
Old 07-05-2014, 07:41 PM   #7
LeviG2010's Avatar
Mine will hit just under 30 and will turn on.
Old 07-05-2014, 10:51 PM   #8
B52Bombardier's Avatar
A TPMS fault is the msg you get when there is an error in the system. Low tire pressure is what you get when your tires need air.
I had a bad sensor (band type in my 07 not the stem type) and got the "fault". Fixed with a new sensor ($25 off eBay).
B52Bombardier is offline   Reply With Quote
Tire Pressure Sensor Fault? Black8thElement Mustang Wheels & Tires 4 04-28-2014 07:31 AM
Disconnected Battery now runs rough bradh2414 1996-2004 Mustang GT 9 08-01-2013 07:40 PM
E brake came disconnected Curt 1996-2004 Mustang GT 0 06-02-2012 03:56 PM
Crack cover, not my fault! Who the hell doesnt torque the bolts down on IRS brace! drusmith 1996-2004 Mustang GT 12 03-16-2011 05:33 PM
I was involved in an accident that wasn't my fault, any suggestions what to do now? Attorney? avsalom Classic Mustangs 3 08-24-2009 04:40 AM
02:39 AM
