code and fail safe help - Mustang Evolution
Old 07-10-2014, 03:03 PM   #1
p_gehle41's Avatar
Hey everyone. My 05 gt has intermittently been going into failsafe mode. Finally tripped the CEL and pulled the codes p2106 and p2135. Local parts store diagnosed it as needing to replace the pedal assembly. I called ford and they said I need to replace the entire throttle body. So what is it? Anyone had the same issues. I bought a new throttle position sensor a few weeks ago but haven't put it in. Any advice or experiences is much appreciated. The car is stock minus an x pipe and axle backs.
p_gehle41 is offline   Reply With Quote
Old 07-10-2014, 03:52 PM   #2
Terminator's Avatar
Had the same issue I bought a new throttle body from oval industries 100 bucks an issue went away was freaking out when i was in traffic an it went into safe mode not the greatest feeling Lol
Terminator is offline   Reply With Quote
Old 07-10-2014, 09:48 PM   #3
p_gehle41's Avatar
That's not too bad! Ford quoted me $300. Guess the TPS I bought wont fix it! I saw there was a tsb on it but im not under warranty. Not too excited about needing a new throttle body after only 77k miles.
Old 07-10-2014, 09:53 PM   #4
S281's Avatar
I had the same problem, same codes. Replaced the TPS and it hasn't done it since
S281 is offline   Reply With Quote
Old 07-10-2014, 10:16 PM   #5
p_gehle41's Avatar
Really? I have the new tps sitting in my glove box. Maybe ill throw it on and see if it fixes it. Any special instructions or just take it off and put in the new one? I read something about checking voltage of the old one
Old 07-11-2014, 02:12 AM   #6
Abominable Mustang
WhoDat's Avatar
Region: Alaska
It should just be a quick remove and install since it's just the sensor, but it's always a good idea to check the voltage reading. This will show you how to check it, as well as adjust it if needed: 05-09 GT Throttle Body Install
2012 Kona Blue 3.7L V6:
Old 07-11-2014, 12:01 PM   #7
p_gehle41's Avatar
Ill have to see if I can find a voltmeter. If I cant will just replacing it work? Also, Do I need to do the battery disconnect/relearn procedure?
Old 07-11-2014, 12:07 PM   #8
S281's Avatar
I just replaced it. Since your putting it on the stock throttle body I wouldn't think the voltage would be an issue. Wouldn't hurt to disconnect the battery
Old 07-11-2014, 03:52 PM   #9
p_gehle41's Avatar
Thanks for all the input! Its frustrating ford says I need a new throttle body, and the local parts place said I need a new pedal assembly. Since I already bought the TPS ill throw it in this weekend. Update to follow! Will the CEL go away? Even though the battery disconnect should clear it
Old 07-11-2014, 08:51 PM   #10
Abominable Mustang
WhoDat's Avatar
Region: Alaska
The CEL should clear when you disco the battery. If not, your local parts store can clear it for you.
Sent from your mom's house.
Fail Safe help p_gehle41 2005-2010 Mustang GT 5 06-27-2014 01:26 PM
Does a deleted ABS throw a code that can fail you for state inspection? scottydsntknow 1996-2004 Mustang GT 3 04-26-2013 06:50 AM
Speedo fail help Evolution Pre-2005 V6 Mustang 8 02-24-2013 07:41 PM
FORD MUSTANG BRAINIACS what does r-code and/or c-code mean? kele74 Classic Mustangs 4 03-16-2010 05:12 PM
Ford, Toyota Benefit from Cash For Clunkers, GM and Chrysler Fail OsirisGuy General Mustang Discussion 1 09-03-2009 01:29 PM
08:21 AM
