Boosting - Mustang Evolution
Old 07-13-2014, 07:50 PM   #1
YutStang's Avatar
Boosting
Ok, so I'm deeply considering getting the whipple kit for my 08 GT. I have no clue how safe this is going to be on my stock engine. I have a aftermarket exhaust (headers & back), under drive pullies, a 4.10 rear end, hurst short shifter, and other cosmetics. If I were to just slap on everything that came with the kit, would it be safe for a daily driver? If so, how safe? And if not, what all would I need to build up before I supercharge my 4.6L?
YutStang is offline   Reply With Quote
Old 07-13-2014, 08:53 PM   #2
YutStang's Avatar
I'm also considering the Roush R2300. Opinions on whipple vs the 2300?
Old 07-13-2014, 09:30 PM   #3
2 Stangz's Avatar
Region: Nevada
Welcome to MEVO. I'm assuming the kit has everything necessary for the S/C upgrade, so you should be fine with the kit. However, you'll have to run really low boost. The stock 3v 4.6 apparently can only handle up to 450 hp. At that point, you'd have to build your motor with stronger internals.
If you leave your motor stock, it'd probably be a better choice to get the Roush R2300 and just run low boost. The Whipple seems to be a much better blower, but you wouldn't be able to utilize it very well on a stock motor.
Old 07-14-2014, 12:03 AM   #4
gqsmash's Avatar
I did brenspeeds r520 kit about a month ago and my internals are stock and it seems good so far! It's the r2300 and I think it's 6-8 lbs boost? I was torn between the whipple as well but when I went to buy the 550 kit from American muscle in the black not chrome they didn't have it anymore so I went with brenspeed....couldn't be happier! (Unless I had a built motor!)
gqsmash is offline   Reply With Quote
Old 07-14-2014, 03:09 AM   #5
YutStang's Avatar
In terms of getting stronger internals, what does that include?
Old 07-14-2014, 06:35 AM   #6
boink's Avatar
I believe you'll also have to put your under drive pullies back to stock before a SC install...
2007 Mustang GT/CS Convertible - AT - Redfire
Bama 91R-V2 Tune - Roush CAI - FRPP GTA Axlebacks - 3.31 Gears
boink is offline   Reply With Quote
Old 07-14-2014, 08:14 AM   #7
Aggiesrok's Avatar
Forged crank, connecting rods, pistons, etc. basically the rotating assembly is beefed up to handle higher rpms and more torque.
Boosting soon....advice? milgt 2011-2014 Mustang GT 35 11-21-2012 04:14 PM
Boosting gas mileage Mustang 4pt0 AmericanMuscle 10 03-13-2012 03:10 PM
Compression/boosting gregtommy 2011-2014 Mustang GT 13 09-12-2011 10:42 PM
Boosting a 2007 Civic EX? natal General Car Discussion 2 03-06-2010 02:08 AM
12:27 PM
