Replace timing chain?? - Mustang Evolution
Old 07-15-2014, 09:14 AM   #1
Bennyhill's Avatar
I'm about to replace and install new timing chains. Just wanted to make sure I have all my ducks in a row concerning having everything I need to do the job right the first time. Please if you haven't physically installed new timing on a 3v 4.6 then don't respond!
Ok so far
New timing chains..
Rh and Lh timing chain tensioners,
Crankshaft bolt ,
Gaskets-
Engine front cover gasket,
Crankshaft front oil seal
Black gasket maker.
That's my parts list. Anything I'm missing? Do I have to remove my heads? New head gaskets? I read somewhere I need a valve spring compressor tool? Do I really need to remove 3 valve steams from each head? Seems like a little much. Anyways thanks for anyone's input on this..
Bennyhill is offline   Reply With Quote
Old 07-15-2014, 09:32 AM   #2
Phaser to cam bolts?
gregthomas is offline   Reply With Quote
Old 07-15-2014, 10:50 AM   #3
Aggiesrok's Avatar
I had to replace a VCT cam sprocket, the clock spring broke. You might consider replacing those since you're already in there. Im not sure what their life is supposed to be. If you do, then you definitely need the phaser bolts, if you just remove them, you'll need new bolts too.
Chevy runs deep, don't step in Chevy.
Old 07-15-2014, 11:11 AM   #4
Bennyhill's Avatar
Ok sweet I will google and look into changing those too. Thanks
99-04 GT Timing Chain tool? FORDGT14 1996-2004 Mustang GT 10 09-10-2011 02:06 PM
Timing chain cover Pascullon Pre-2005 V6 Mustang 2 02-10-2011 06:17 PM
timing chain ?'s white98gt 1996-2004 Mustang GT 6 02-04-2011 09:04 AM
Timing Chain Needed! tjzola 1996-2004 Mustang GT 3 06-02-2010 01:30 AM
Brand New in Package Ford Racing Double Roller Timing Chain Set wvstang5.0ho Mustang Parts for Sale and Wanted 2 01-31-2009 06:13 AM
11:34 PM
