Tire Size with Traction control/ abs on 05 mustang - Mustang Evolution
Old 08-03-2014, 01:53 PM   #1
SilverBullett's Avatar
Region: Arkansas
I have original Stock Pirelli's Tires 235/55/17 with only 34k with 7/32nds left.my 05 gt stang was garage parked most its life. Im not impressed with the tires,they dont Hook up that good. Im planning to get Nitto NT555 255/50/17 for the rear.i never had problems with nittos hooking up on my 04 gt.
Will The Traction Control system / ABS light go off if i have 235/55/17 in the front and 255/50/17 in the rear? i used the tire calculator Tire 1= 235/55/17 Tire 2 255/50/17.
Results
Totals are in inches Tire 1 Tire 2 Difference
Sidewall Height: 5.09 5.02 -0.07
Section Width: 9.25 10.04 0.79
Overall Diameter: 27.18 27.04 -0.14
Circumference: 85.38 84.95 -0.43
Revs per mile: 742.1 745.88 3.78
SilverBullett is offline   Reply With Quote
Old 08-05-2014, 12:16 AM   #2
Aggiesrok's Avatar
Once any tire slips, Traction control kicks in. If you're launching turn it off, so when you slip a little it won't cut the throttle. I like Nitto better than pirelli's. You need to replace the factory rear Lower control arms for some stiffer aftermarkets. It helps a lot with wheel hop.
Old 08-05-2014, 07:34 AM   #3
Region: Arkansas
So having different tire sizes won't turn on the abs fault light ???thats what I'm trying to figure out ,I heard from other friends with stangs if you have different tires sizes from the front to rear ,it will turn I the abs light on the dash .i also am planning to buy lower rear controls arms ,what the best deal when your on a budget ?
Old 08-05-2014, 07:45 AM   #4
Abominable Mustang
WhoDat's Avatar
Region: Alaska
Tires that close of a size shouldn't trip your ABS.
Sent from the Death Star.
2012 Kona Blue 3.7L V6:
Old 08-05-2014, 09:25 AM   #5
Aggiesrok's Avatar
The traction fault comes on when there is tire slipping, not because of a different tire. It's a safety feature mostly for driving in the rain, when it feels the rear tires slip it cuts throttle and stops the slipping. Not a good feature for launching.
LCAs are fairly cheap, a little over $200. The big thing is to get poly bushings and not rubber. Also you must buy new bolts, because they are stretched when installed and not good for re-use.
Chevy runs deep, don't step in Chevy.
ABS light + traction control doesnt work RedGT04 1996-2004 Mustang GT 16 11-12-2015 06:43 PM
ABS light on and Traction Control off Constantine 1996-2004 Mustang GT 16 11-14-2013 05:43 AM
ABS & Traction Control light ON!!! Stryker01 2005-2010 V6 Mustang 3 02-22-2013 08:31 PM
Different Tire Size and Traction Control/ ABS Issues TimeMachine 2011-2014 Mustang GT 17 07-04-2012 11:08 PM
ABS and Traction control light on rugman1969 1996-2004 Mustang GT 1 09-30-2006 03:09 PM
03:59 PM
