Help I think I have a tuner problem. - Mustang Evolution
Old 08-03-2014, 08:15 PM   #1
BlackPonyIHave's Avatar
Ok so I'm on the freeway with my tom tom GPS on and it says I'm doing 70 mph. My speedometer says I'm doing 80( which I don't believe to be true) then when I was in town it was off 5to 7 mph. Before I left I tuned it to that tune from a diablo sport 93 octane performance tune. So when I noticed the speedometer was not right, I stopped and retuned it back to a 93octane tune. It didn't fix anything. So when I got home, I tuned to back to original tune and it didn't fix nothing. Is this a tuning problem? Or is this something else?? Thanks
4.6 engine,Ford Racing torque bar, diablo performance 93 octane tune, cold air intake with a K&N filter, SLP exhaust from axle back, 3.73 ford racing gears
BlackPonyIHave is offline   Reply With Quote
Old 08-03-2014, 08:18 PM   #2
Rapinator126's Avatar
What size tire are you running? And what size did you tell them for your tune?
Same for the rear gear, what ratio did you tell them? And what ratio are you running
Rapinator126 is online now   Reply With Quote
Old 08-03-2014, 08:23 PM   #3
I bought if from a dealer like this. It had the 93 tune when I got it. The tire size is stock size. The gears were changed by old owner from 3.31 to 3.73. The tune is just a tune that came with the tuner, it wasn't customized for my car I don't believe....
Old 08-03-2014, 08:43 PM   #4
So I just googled this and it seems like I have to change this in my tuner somehow. Flash it or something. Hmm I have a predator diablo sport tuner, I see there is a option to modify a tune. Guess I'm going to have to figure this out. Any advice is appreciated!
Old 08-04-2014, 01:24 AM   #5
Abominable Mustang
WhoDat's Avatar
Region: Alaska
When you modify the tune parameters. Make sure the rear gear ratio is set to 3.73. I'm willing to bet the tune you're running has it set to the factory 3.31.
Sent from the Death Star.
2012 Kona Blue 3.7L V6:
Old 08-04-2014, 01:49 AM   #6
2 Stangz's Avatar
Region: Nevada
Ditch the canned Diablo tune and purchase a tune(s) either from a reputable email tuner or performance shop in your area. I've heard the canned tunes that are pre-loaded in the tuners aren't safe. Plus, someone who has experience tuning Mustangs will make much better tunes rather than what you may have now.
Old 08-04-2014, 04:43 AM   #7
boink's Avatar
+1 on getting some custom tunes. Before spending money on any other performance mods, like udp's, I would enroll in a tunes for life program with AM or Steeda for around $150.
Sent from my microwave
2007 Mustang GT/CS Convertible - AT - Redfire
Bama 91R-V2 Tune - Roush CAI - FRPP GTA Axlebacks - 3.31 Gears
boink is offline   Reply With Quote
Old 08-04-2014, 05:14 AM   #8
utm18's Avatar
Hypermotive has tunes for $100.
utm18 is offline   Reply With Quote
Old 08-04-2014, 06:49 AM   #9
ok so until I can afford a better tuner than the one I have. Can someone walk me through how to modify my gear ratio with this tuner to get my speedometer right?
Old 08-04-2014, 08:17 AM   #10
Cbird's Avatar
Region: Iowa
Pick the tune you want to run and then there should be a option that is similar to "modify tune". Then change the gear ratio to 3.73:1 and then write it to the cpu.
I'm my opinion that will fix your issue.
Sent from my SPH-L710 using Mustang Evolution mobile app
Cbird is offline   Reply With Quote
Old 08-04-2014, 08:37 AM   #11
Thanks Ill try that. I seen an option that says modify tune. i went in there but never had changed anything. I just went there to see what options was there to change. When I get home from work today, ill try that.
Old 08-04-2014, 02:04 PM   #12
Ok I fixed the speedometer issue. Found the axle ratio mod and changed it to 3.73 and its at the right speed now. I see this other option for tire revolutions per mile. It is set on 771. But I went online and found a calculator and it says 742 revs per mile. Should I change that to?? My tire size is 235/55/R17
4.6, K&N CAI tuned, torque bar, SLP Exhaust
Old 08-05-2014, 10:04 AM   #13
So no one knows what my revolutions per mile should be set at in my tune? The tune has it set at 771 per mile now but i found a online calculator that says my tire size goes 742 revs per mile. Should I change that?? Thanks
Old 08-05-2014, 10:11 AM   #14
Yes
Old 08-05-2014, 10:12 AM   #15
bucko's Avatar
Have you contacted the customer support team of your tuner? They would be the "safest" place to start in getting the correct answer(s) to these types of tuner custom parameter changes.
Old 08-05-2014, 01:03 PM   #16
No but I will. Thanks
Houston. I think we have a problem MasonStacks General Mustang Discussion 18 02-28-2014 09:15 PM
I have an electrical problem help!! 99saleen87 1996-2004 Mustang GT 17 03-11-2011 11:25 PM
Transmission problem.... I think...HELP! BbV06Stang Pre-2005 V6 Mustang 8 06-07-2009 10:59 PM
I think I have a problem ... braumab The Bar 22 12-17-2008 09:39 PM
11:39 AM
