Intake manifold - Mustang Evolution
Old 08-13-2014, 05:38 AM   #1
S197Miller's Avatar
Intake manifold
What rpm does the ford racing intake stop flowing?
I have a lot done to my motor but have the stock intake. The dyno shows that the power starts to flat line around 5500. I need an intake that will flow over 7000. Will the frpp intake do that?
Sent from my SPH-L710 using Mustang Evolution mobile app
S197Miller is offline   Reply With Quote
Old 08-14-2014, 06:23 AM   #2
08Mustang's Avatar
Yeah it'll raise your operating range....what all do you have done to the motor?
08Mustang is offline   Reply With Quote
Old 08-14-2014, 06:52 AM   #3
S197Miller's Avatar
Stroked. Bored. Heads. Cams. 11.4:1 compression. Every bolt on. Full exhaust.
Old 08-14-2014, 06:57 AM   #4
08Mustang's Avatar
Then yeah get that stock intake off there now! Lol Those charge motion control plates are choking your motor
Old 08-14-2014, 06:59 AM   #5
S197Miller's Avatar
I have the delete plates
Old 08-14-2014, 07:03 AM   #6
08Mustang's Avatar
Gotcha, I know the Ford Racing intake doesn't necessarily make a lot more power than delete plates with the stock intake but I think it is more of a high rpm design. What size injector you running?
Old 08-14-2014, 07:05 AM   #7
S197Miller's Avatar
Overkill will 47lbs
But the motor is built for spray. So this winter is coming a 200-300 shot.
I just need more rpms. Near Peak power shouldn't be under 6k. It should be over 7k
Old 08-14-2014, 07:06 AM   #8
Rapinator126's Avatar
Originally Posted by S197Miller View Post
Overkill will 47lbs
Better have a direct port, and a dedicated fuel sytem.
Old 08-14-2014, 07:07 AM   #9
08Mustang's Avatar
Yeah what fuel pump you running? Stock?
Old 08-14-2014, 07:07 AM   #10
Was the ring gap set for a big shot?
Old 08-14-2014, 07:10 AM   #11
S197Miller's Avatar
Yes the gap as set for a 300 shot. And right now it's the stock pump. I wanted to get the car running NA first.
Direct port is the only way to do it.
Old 08-14-2014, 07:11 AM   #12
08Mustang's Avatar
You're probably close to maxing out the stock pump then
Old 08-14-2014, 07:12 AM   #13
I'm not talking about stock pump.
You will need a standalone fuel system for a 300 shot.
A completely different system from your stock system.
---------- Post added at 08:12 AM ---------- Previous post was at 08:11 AM ----------
What fuel you going to run?
Old 08-14-2014, 07:13 AM   #14
S197Miller's Avatar
Ya the separate fuel system sits in place of where the stock battery goes.
I'm running ms109
Old 08-14-2014, 07:14 AM   #15
08Mustang's Avatar
Rap I know NOTHING about nitrous haha, I'm just saying if he was never going to run nitrous and just be all motor then he's maxing out the pump for that fuel system. Anything close to 400 is about it for the stock one right?
Old 08-14-2014, 07:16 AM   #16
Lol its all good bud.
A 200 shot shot it alot on the stock system. The reason is bc it goes lean on the initial hit. ( sucks all the fuel out of the rails)
Thats why a standalone is needed for anything over a 200.
Old 08-14-2014, 07:17 AM   #17
08Mustang's Avatar
No I mean 400hp
Old 08-14-2014, 07:18 AM   #18
S197Miller's Avatar
Yep. Rapinator, so you know they problem I'm having with rpms and power. You think the frpp intake will solve my issue?
Old 08-14-2014, 07:24 AM   #19
No I mean 400hp
Ahhhhh **** lmao.
Lol yes 400hp at the tires on the stock 3v fuel system is getting up there. 450 is about max on boost a pump.
I know I was pushing it on my old 3v on the stock pump at mid 400 ' s
---------- Post added at 08:24 AM ---------- Previous post was at 08:23 AM ----------
*450-500.
Old 08-14-2014, 07:30 AM   #20
There are people getting 7k out of the FRPP intake. What cams did you go with though? What the operating range?
You could always get the Spyder intake manifold from MMR.
Old 08-14-2014, 07:36 AM   #21
S197Miller's Avatar
They are the comp spr stage 3. They spec above 7100. And they spyder intake is a chunk of money.
Old 08-14-2014, 07:39 AM   #22
Yes it is.
But you will be good with the FR intake.
What nitrous sytem you going with
Old 08-14-2014, 07:40 AM   #23
08Mustang's Avatar
I wish someone made an intake for the 4.0 lol
Old 08-14-2014, 07:45 AM   #24
S197Miller's Avatar
Yes it is.
Not jumping Into it right now. This stroker has drained me.. not in a good way either. I don't want to put much thought into right now. Just want to worry about getting the car running right.
But. Nitrous outlet has a direct injection system for the 3v. Tucked away and hidden from view.
What about the jpc intake manifold?
Old 08-14-2014, 07:47 AM   #25
Never saw the JPC one for the 3v. All there stuff is good though. So I'm sure it will be better then the Ford one.
Old 08-14-2014, 07:48 AM   #26
S197Miller's Avatar
It's just hard to find. I don't even think they sell it on their website
Old 08-14-2014, 07:50 AM   #27
08Mustang's Avatar
What size is the engine now after you bored and stroked?
Old 08-14-2014, 07:52 AM   #28
S197Miller's Avatar
It comes out to a little over 302
Boss intake manifold and the stock intake Yellow50 2011-2014 Mustang GT 43 04-26-2012 06:30 AM
Intake Manifold vs Intake Man-child jbanks 1996-2004 Mustang GT 17 08-02-2011 04:55 AM
Ported Intake Manifold..STRESS 99'sleeper Pre-2005 V6 Mustang 5 03-10-2005 08:10 AM
95 Intake manifold. Calston31 Pre-2005 V6 Mustang 6 12-05-2004 05:42 AM
Intake manifold and cylinder head jwscorpio Pre-2005 V6 Mustang 4 02-27-2004 06:49 AM
» Members Mustangs
Kraken
Cise
Kona Blue
Kona
Add your Mustang
12:03 PM
