Battery losing charge - Mustang Evolution
Old 09-22-2014, 08:35 PM   #1
Minus2380's Avatar
I just bought a 2007 mustang and after a month of buying it, it starting to die out after sitting in the garage for the night. It doesn't go completely dead, it still clicks when I try to start it in the morning. When we put jumper cables on it it fires right up. CAN SOMEONE PLEASE HELP!!!!!
Minus2380 is offline   Reply With Quote
Old 09-22-2014, 08:48 PM   #2
Tyoung68's Avatar
Well batteries usually last 4-6 years soo my guess is a bad battery
Old 09-22-2014, 09:15 PM   #3
Minus2380's Avatar
Autozone is saying it's still good. But it is "autozone" that's telling me that. Lol. Could it be the Voltage regulator?
Old 09-22-2014, 09:19 PM   #4
Tyoung68's Avatar
I worked at autozone and those machines don't always work. How do your cables look?
Old 09-22-2014, 09:52 PM   #5
Minus2380's Avatar
Almost perfect.
Old 09-22-2014, 10:24 PM   #6
Tyoung68's Avatar
Did you only have them check the battery? They can check the alt. too
Old 09-23-2014, 06:50 AM   #7
Minus2380's Avatar
Yea just the batt. I'll have them check the alt today
Old 09-23-2014, 08:37 AM   #8
KamzGT's Avatar
I have an 07, same thing happened to me. The alternators are a big problem for that year, once you replace the stock alt you will be fine, they go out at 40-60k miles. Mine was 50k. They just built them poorly that year
KamzGT is offline   Reply With Quote
Old 09-26-2014, 10:36 PM   #9
gqsmash's Avatar
You fix the problem? Charge the battery then unplug it completely then in the morning plug it up and try...that will tell you real quick if it's your battery
gqsmash is offline   Reply With Quote
Old 09-28-2014, 11:24 AM   #10
08AlloyGT's Avatar
You might try pulling the fuse for your Shaker amps if you have them. I had a bad amp when I bought my car. It would stay on and drain the battery. Make sure you fully charge the battery after it goes dead. Jump starting it isn't enough.
08AlloyGT is offline   Reply With Quote
Old 09-28-2014, 12:41 PM   #11
Cbird's Avatar
Region: Iowa
Nice! Good thinking
Cbird is offline   Reply With Quote
Changing alternator. Should I charge the battery? Bryan02V6 Pre-2005 V6 Mustang 40 11-13-2012 06:47 PM
Helping gas without losing power back from iraq 1996-2004 Mustang GT 4 08-06-2008 08:18 PM
Cant win For Losing ridenmystang The Bar 9 05-31-2007 10:45 AM
haha Alabama is losing to Duke 14-10 Brent The Bar 9 10-08-2006 09:02 PM
07:59 PM
