Need help! - Mustang Evolution
Old 09-24-2014, 07:12 AM   #1
Turtlestang39's Avatar
Need help!
Hello guys,
So for the last couple of months I've noticed that my car seems to either skip or struggle to catch the next gear while trying to accelerate while in movement. If I try to step on it from a dead stop it doesn't happen. But if I'm trying to pass someone and I'm between 2000 to 3000 it struggles to catch the extra boost. Everything is stock.
Have anyone had the same issue or might now what this is?
Thank you.
Turtlestang39 is offline   Reply With Quote
Old 09-24-2014, 08:29 AM   #2
KamzGT's Avatar
Check your throttle body.
KamzGT is offline   Reply With Quote
Old 09-24-2014, 09:11 AM   #3
boink's Avatar
[QUOTE=KAMZ01MUSTANG;2096382]Check your throttle body.
This...
I picked up a CRC twin back of MAF cleaner and throttle body cleaner for a few bucks at Walmart. I'd suggest cleaning both...
Amazon.com: CRC 05111 Single-Use MAF and Throttle Body Cleaner - Twin Pack: Automotive
2007 Mustang GT/CS Convertible - AT - Redfire
Bama 91R-V2 Tune - Roush CAI - FRPP GTA Axlebacks - 3.31 Gears
boink is offline   Reply With Quote
Old 09-24-2014, 04:44 PM   #4
S281's Avatar
If it's an automatic. Check your fluid level.
S281 is offline   Reply With Quote
Old 09-25-2014, 09:36 AM   #5
Yea I will the CRC cleaners and try it this weekend. Hopefully that's the issue.
In regards to the fluid. Is there a way of checking the fluid without refilling it?
Old 09-25-2014, 01:09 PM   #6
What year? how many miles? have the plugs ever been changed? Any mods, or recent mods? lots of variables here
Kylar is offline   Reply With Quote
Old 09-25-2014, 06:50 PM   #7
2006 - 75k miles - I bought it with 40k miles on it and I have never replaced the plugs since I bought it. No mods at all.
Old 09-26-2014, 09:04 AM   #8
Cbird's Avatar
Region: Iowa
You're plugs are likely not the culprit then. I agree it sounds like a throttle issue as well.
Cbird is offline   Reply With Quote
Old 09-29-2014, 06:39 AM   #9
Cleaned the throttle and the MAF sensor but the issue didn't go away.
Any other ideas? I'm still hoping is a cheap inexpensive solution.
Old 09-30-2014, 10:45 AM   #10
NADENE05's Avatar
Does an indicator of a wrench light up on your dash? If so, def check ur throttle body, spark plugs, or air intake. I hope it's a semi-easy fix.
NADENE05 is offline   Reply With Quote
Old 09-30-2014, 10:06 PM   #11
No there is no indicator. The car runs normal most of the time but sometimes the issue happens.
Old 10-01-2014, 07:19 AM   #12
NADENE05's Avatar
Take it to you nearest auto part store or your mechanic. Have them run a diognastic through the computer port with a code reader. See what codes come up in order to give some indication of what it could really be.
Old 10-01-2014, 11:19 AM   #13
Cbird's Avatar
Region: Iowa
Does it seem like when you put your foot down there is a delay between when your foot hits the floor and when the car downshifts?
I had a 05 v6 years ago that would sometimes hang in overdrive when flooring it for a few seconds before down shifting and opening the throttle. It was annoying to say the least, but could also be dangerous if you were trying to floor it away from a hazard.
Need quick help! Need to find 4.10 gears for 2010 v6 mustang?? Camaro Eater Pre-2005 V6 Mustang 2 06-08-2010 05:31 AM
Guys need help.. going to get new engine.. need advice Skyes97Stang Pre-2005 V6 Mustang 9 11-28-2009 12:35 AM
need some help from the electrically inclined (need to find a power transformer) fast64 The Bar 5 05-26-2006 03:58 PM
Need to choose new tires..need help KyleUSAF Mustang Wheels & Tires 13 11-29-2005 11:13 AM
Need Help with Viruses on my COMPUTER! HELP ASAP!! Autobadges.com The Bar 41 02-05-2004 09:53 PM
06:51 PM
