Whining in engine - Mustang Evolution
Old 09-27-2014, 04:50 PM   #1
Zcarmack16's Avatar
Whining in engine
There as been a whine coming from the engine lately. I read up on this and found out it could be the idlers. I just replaced all the idlers and tensioner and it still has been making the noise so it's not any of those. I know it isn't the power steering and it doesn't make the noise at an idle. It just does it on acceleration and going a constant speed. Any ideas on what it could be?
Zcarmack16 is offline   Reply With Quote
Old 09-27-2014, 05:37 PM   #2
2 Stangz's Avatar
Region: Nevada
Blower fairy came
Check back in a few weeks
Old 09-27-2014, 05:54 PM   #3
Cbird's Avatar
Region: Iowa
Are you sure it's coming from the engine? I've had two things like this happen to me, although both on my 01. They were old differential fluid and a wheel bearing.
If it doesn't make the sound when revving in neutral then it's likely driveline related and not engine related.
It always sucks having to track down noises when the car is running perfectly fine. I know that feel bro
Cbird is offline   Reply With Quote
Old 09-27-2014, 06:54 PM   #4
Zcarmack16's Avatar
It doesn't do it when you rev it. So What about the driveline? Anything serious?
Old 09-28-2014, 04:22 PM   #5
Aggiesrok's Avatar
Is it auto or manual?
Make sure you're mother-in-law isnt in the back seat.
Chevy runs deep, don't step in Chevy.
Old 09-28-2014, 07:49 PM   #6
Zcarmack16's Avatar
Auto
Old 09-28-2014, 09:22 PM   #7
Aggiesrok's Avatar
When driving at a constant speed, if you put it in neutral, does the whine stop or change?
Old 09-29-2014, 10:45 AM   #8
Zcarmack16's Avatar
The whining goes quieter as the rpms go down.
Old 09-29-2014, 03:39 PM   #9
Cbird's Avatar
Region: Iowa
Does it go away completely if the trans in in neutral? We are trying to figure out if its transmission or motor related. If the noise is still there when you are in neutral then it leads to transmission, even more so since you said you can't hear the noise when revving.
If it is in fact a transmission whine then low fluid and even a bad transmission mount come to mind.
Old 09-29-2014, 04:37 PM   #10
Zcarmack16's Avatar
No it's still present if you put it in neutral.
Old 09-29-2014, 04:39 PM   #11
Zcarmack16's Avatar
How do you check transmission fluid? I have never found a spot to check it.
Whining noise coming from engine area johnb554 2005-2010 Mustang GT 13 05-05-2017 05:55 PM
2012 5.0 whining noise? Superstang General Mustang Discussion 8 01-25-2012 08:15 PM
whining noises? 96civic87 Pre-2005 V6 Mustang 12 11-15-2011 01:52 PM
8.8 rear end whining 67mustang97 1996-2004 Mustang GT 2 04-18-2010 09:34 PM
Whining noise? SVTCOBRA Pre-2005 V6 Mustang 13 02-20-2010 11:58 AM
06:59 AM
