Need advice on my 0-60ft. Time - Mustang Evolution
Old 10-04-2014, 12:38 PM   #1
stanzmustang08's Avatar
Soooooo I'm 2 stepping at 5000rpm, hook up is great. Then a quick lag comes and goes in first gear. Then I'm good for 13.1 in the 1/4 mile.
At 360 rwhp, I should be in the 12's. The problem lies in the 0-60. At it's best, it's 2.1 seconds.
Any ideas what the hiccup could be???
stanzmustang08 is offline   Reply With Quote
Old 10-04-2014, 06:57 PM   #2
gqsmash's Avatar
What kind of tire you running...I haven't been in awhile but at 299hp with nitto 555s and 4.10s I ran 13.4 with 2.0 60...and I was launching at around 2k cause I'm no pro when it comes to slippin the clutch
gqsmash is offline   Reply With Quote
Old 10-04-2014, 07:24 PM   #3
My tires are Mickey Thompson 273/65's
---------- Post added at 01:24 AM ---------- Previous post was at 01:24 AM ----------
Sorry about the typo 275/65
Old 10-04-2014, 09:28 PM   #4
Lorraine's driver
ab_mach1's Avatar
If you have a manual tranny, you could try slipping the clutch some to stop the bogging. Usually you gotta slip to stop spinning. Seems like it might help in your case though.
Instagram: @ab_mach1
Old 10-04-2014, 10:04 PM   #5
Ya, maybe I don't use the 2 step anymore and just try on my own feel with the clutch. I swear that's where th problem lies in my 0-60ft.
Old 10-05-2014, 07:21 AM   #6
I'm gonna to try to get to the track Wednesday night. I'll try slipping the clutch and let you know how it went.
Thanks
Old 10-05-2014, 07:39 AM   #7
Lorraine's driver
ab_mach1's Avatar
We've got only 2 more test and tune days left before they close the track for the season out here. I'm hoping to go to at least one. I'm planning to do try this as well. My 60ft's are always 2.2__ and I can't get DR's or slicks right now. I think I can work the clutch a little get it down. Every .10 you shave off is about worth .20 lower 1/4 time as long as the rest of the run goes well. That's the theory anyways.
If it doesn't seem to help your bogging, you could try launching at a higher RPM, but damn I'd be afraid about the drivetrain holding up unless it's built.
Good luck man!
2004 Azure Blue Mach 1
IG: @azurebluemach
Old 10-05-2014, 08:03 AM   #8
We have until Halloween night. That's the last street night then the track closes.
I bet the last night (Halloween) will be a FREAK SHOW lmao!
Old 10-05-2014, 08:07 AM   #9
Oh by the way, 5000rpm is definitely my max take off. I slipped at 5200
Old 10-06-2014, 05:35 PM   #10
BaSohol's Avatar
Run Hoosier QTPs 11.5x26x15
Sent from my SAMSUNG-SM-N900A using Mustang Evolution mobile app
2007 Ford Mustang GT 5spd
Old 10-06-2014, 07:59 PM   #11
I concur with this
Old 11-02-2014, 06:09 AM   #12
Just want to let you guys know that I hit 12.8 on Halloween night!
That was my last chance to get into the 12's before track closed for the season.
I hit 12's 4 times. Switched to 4:10 gears and it improved my 0-60'
Old 11-02-2014, 03:20 PM   #13
lindertw's Avatar
what suspension mods have you done to the car? ditch the drag radials and get either Hoosier QTP or M/T ET street bias ply rear tires, they work so much better with a manual trans.
my 2005: 302 rwhp, stock clutch/shifter/2pc driveshaft, 4.10 gears with truetrac diff, metco UCA and LCA's, BMR relocation brackets, strange single adj struts/shocks, cobrajet drag springs, M/T et street bias ply tires (26").
Best 60' so far is 1.611 launching at 6500 off the limiter (clutch dump)
good luck getting it all sorted out!
2005 GT, N/A 302rwhp/317rwtq, 3500 lbs
12.095 @ 111.08, 1.576 60'
lindertw is offline   Reply With Quote
Old 11-02-2014, 03:46 PM   #14
That's a great launch!
I just switched to 4:10's. I've yet to do anything to the suspension. Clutch is stock. Launching at 5000 with my 2 step.
Horrible 60ft times any ideas? Bottlefed stang 2011-2014 V6 Mustang 22 09-04-2014 06:33 PM
Need opinions and advice first time engine swap soon Gobabygo67 1996-2004 Mustang GT 16 08-21-2013 10:45 AM
Time for a tune, advice time. drivinglesson 2011-2014 Mustang GT 30 07-26-2011 06:54 PM
Guys need help.. going to get new engine.. need advice Skyes97Stang Pre-2005 V6 Mustang 9 11-28-2009 12:35 AM
desire advice... stock investment type advice... dark The Bar 4 04-23-2006 06:07 PM
06:49 AM
