Help! Flooded, won't start. - Mustang Evolution
Old 10-06-2014, 07:38 PM   #1
YutStang's Avatar
I installed a procharger, started my car on the stock tune, and flooded my engine. The fuel pump works, the engine cranks, but does not start. I'm 90% sure that it's flooded. I tried taking the fuel pump fuse out and cranking the engine, didn't help. What do you suggest that I do to get the car to start? It's a 2008 GT. I'm trying to avoid taking the plugs out, it seems to be a little bit of a challenge. I've never changed spark plugs. Any advice will help! I need my car to run ASAP.
YutStang is offline   Reply With Quote
Old 10-07-2014, 10:22 AM   #2
08Mustang's Avatar
Whyyyyyy did you start it on the stock tune....
08Mustang is offline   Reply With Quote
Old 10-07-2014, 10:32 AM   #3
YutStang's Avatar
I had to move the car and had no other choice.
Old 10-07-2014, 11:57 AM   #4
silvr002001's Avatar
Doesn't pro charger include a tune?
silvr002001 is offline   Reply With Quote
Old 10-07-2014, 12:59 PM   #5
YutStang's Avatar
Yes they do, but I hadn't received the time from them yet.
Old 10-07-2014, 04:03 PM   #6
So you have the tune now?
Old 10-07-2014, 06:33 PM   #7
YutStang's Avatar
Yes, I have it now, but it still won't start. I just replaced the spark plugs, and it still won't start.
Old 10-07-2014, 07:03 PM   #8
What did the engine do when you first started it? Did it run normally until you turned it off? Did you drive it any distance or just move it? Did it just die? I know the manual for my roush supercharger states Do not start the car until the computer has been programmed it can cause catastrophic damage. I'm not saying that's what happened to you and I hope not, but it is a big no no. Hopefully it's just something simple and a quick fix.
Old 10-07-2014, 08:15 PM   #9
YutStang's Avatar
The engine started and rev'd at 1500, then after a few seconds started dropping, like a cold start. The only thing was that it didn't stop dropping RPM's until it died. And the day before, I had the car idling for a minute or two just fine. I was just checking to make sure everything was installed correctly, considering that the procharger doesn't produce any boost until around 3000rpm, and the car did the same thing with the 1500 RPM's, then dropped to a steady 800 rpm. The only difference the second time was that it didn't stop dropping, and now it won't start. It acts as if it is flooded, after sitting for a good 9 hours, it tried to start, but didn't. Changed the spark plugs, they looked like crap. It tried to start again, but didn't. I'm hoping that after sitting another day with new spark plugs, it will start.
Old 10-07-2014, 09:54 PM   #10
Bennyhill's Avatar
Maybe it's not getting gas? Inside passenger side, front under the dash, remove a panel. Inside you will find a "box" on top will be a button you can push in, it will reset your fuel pump.. Just push that down and see if it works..
Bennyhill is offline   Reply With Quote
Old 10-08-2014, 03:57 AM   #11
YutStang's Avatar
I'll definitely give that a shot. I have a fuel pressure gauge, and it reads 0.6 psi when I'm cranking the car. When I took the fuel pump fuse out of the fuse box, it stayed at 0.0 I wasn't sure if that was how much fuel pressure is needed to start the car, or if it was messed up.
Old 10-08-2014, 04:24 AM   #12
YutStang's Avatar
Also, this is what my plugs looked like. Click image for larger version
Name:	ImageUploadedByMustang Evolution1412763840.163795.jpg
ID:	167582Click image for larger version
Name:	ImageUploadedByMustang Evolution1412763850.559810.jpg
ID:	167583Click image for larger version
Name:	ImageUploadedByMustang Evolution1412763864.006659.jpg
Old 10-08-2014, 10:03 AM   #13
YutStang's Avatar
Tried resetting the fuel pump, didn't work. Again, the car almost tried starting, but then wouldn't start and the second try wasn't close to starting at all. Maybe if I just let the car sit a few days without trying to start it, it will dry out and start?
Old 10-08-2014, 10:11 AM   #14
Did it scree up the starter some how?
Old 10-08-2014, 10:18 AM   #15
YutStang's Avatar
The starter is fine. I just pulled the injectors out but left them all connected and cranked the motor and nothing came out of the injectors. Fuel pump problem??
Old 10-08-2014, 10:20 AM   #16
Maybe? How much is a new fuel pump for these cars?
Old 10-08-2014, 10:23 AM   #17
YutStang's Avatar
The starter is fine. I just pulled the injectors out but left them all connected and cranked the motor and nothing came out of the injectors. Fuel pump problem?? But when I took an injector out, there was fuel behind it.
Old 10-08-2014, 10:24 AM   #18
YutStang's Avatar
Not sure how much they are. I had to install a new one though to go with the procharger. What doesn't make sense to me is that when I took the injector out, fuel poured out with it. Not a lot, but some did.
Old 10-08-2014, 01:05 PM   #19
Dago's Avatar
Can you hear the pump when you turn the switch on with out cranking? Checked the pump fuse? also check for the connector for the pump in the trunk if you can't hear the pump
2006 GT, C&L RACER INTAKE, FRPP THROTTLE BODY, FRPP INTAKE MANIFOLD, FRPP HOTROD CAMS, FRPP SHORTY HEADERS, CUSTOM X PIPE, BORLA ATAK MUFFLERS, FRPP SPRINGS, BAMA TUNE, CERVINIS STALKER II HOOD, STREET SCENE GEN 1 FASCIA AND REAR VALANCE
Dago is offline   Reply With Quote
Old 10-08-2014, 01:28 PM   #20
YutStang's Avatar
When I turn the key on I can hear some humming around where my pump is and it stops humming after a few seconds. I'm pretty sure I hooked everything up correctly when I installed the new pump. I'm thinking maybe either the relay for the pump that's in the fuse box, or it's something with the injectors. What is that you were talking about in the trunk?
Old 10-08-2014, 01:57 PM   #21
Boosted_3v's Avatar
Check all fuel system fuses
Boosted_3v is offline   Reply With Quote
Old 10-08-2014, 02:02 PM   #22
YutStang's Avatar
Isn't there only one fuse and one relay?
Old 10-08-2014, 02:04 PM   #23
Tyoung68's Avatar
.6 in not enough pressure did you mess with the pump at all?
Killing time isnt murder, it's suicide
Old 10-08-2014, 02:06 PM   #24
Boosted_3v's Avatar
On my buddy's coyote the fuse box under the hood had some I looked and one was blown if I remember right it was the green one changed it out and bam started right up
Old 10-08-2014, 02:45 PM   #25
NewMtang's Avatar
Why don't you call Procharger direct?
Old 10-08-2014, 03:22 PM   #26
[QUOTE=NewMtang;2104061]Why don't you call Procharger direct?[/
+1
Old 10-08-2014, 04:38 PM   #27
YutStang's Avatar
If I take out the injecors, but leave them all hooked up, when I crank the engine, nothing comes out. I then took them out of the fuel rail and fuel was behind them. I drained all the fuel out of the fuel rail. I then re-installed all the injectors on both sides and tried starting the car. The car started and ran at 600rpms for about 5 seconds then slowly dropped rpm's until it died. I drained the fuel rails again, and the car did the same thing as the first time. I don't think it's bad injectors considering that I drove the car home with them. Idk what it could be! I want to be able to drive my car so badly!!
Old 10-08-2014, 04:39 PM   #28
YutStang's Avatar
Old 10-08-2014, 08:08 PM   #29
Tyoung68's Avatar
Kinda sounds like you have a leak somewhere have you tired cycling the key a few times to build fuel pressure
Old 10-09-2014, 02:39 AM   #30
YutStang's Avatar
I've cycled the key and looked for leaks. I'm probably just going to take the fuel pump out and take a look at it.
Old 10-09-2014, 07:07 AM   #31
Cbird's Avatar
Region: Iowa
Since you can hear it your connector is in place and fine in the trunk.
I'm not a fuel pump wizard but mine makes a whine sound when I prime it. Like "eeeeeee". It doesn't make a "hum" sound.
Cbird is offline   Reply With Quote
Old 10-09-2014, 07:09 AM   #32
YutStang's Avatar
I'm not a fuel pump wizard but mine makes a whine sound when I prime it. Like "eeeeeee". It doesn't make a "hump" sound lol. Maybe it is the pump after all?
Yeah, that's a better description. Mine also makes that kind of noise. Do you think maybe it has something to do with the MAF sensor?
Old 10-09-2014, 08:13 AM   #33
Cbird's Avatar
Region: Iowa
Ok so the fuel pump sounds to be working fine but it's not making its way to the injectors?
If it was the MAF I'm pretty sure you would get a check engine since that is an electrical sensor and not mechanical.
Old 10-09-2014, 08:15 AM   #34
YutStang's Avatar
My check engine light flashes then stays on, but when I check for codes it says there is no fault. I don't know much about MAF sensors. Could it be pegged or dirty? I wish I knew someone else around here with a stang so I could just swap out the MAF and see if that fixes it.
Old 10-09-2014, 09:09 AM   #35
Tyoung68's Avatar
Whats your fuel pressure at now?
« CAI | Gear ratio »
I flooded out my 1985 mustang gt, what can i do to get it started again...? Kellan 1979-1995 Mustang GT 7 12-15-2011 01:32 AM
Where do i check or how i can tell if a car was flooded and fix and been sale like noting happened? woolcott General Car Discussion 3 03-22-2010 03:55 AM
V6 won't start...help stang man Pre-2005 V6 Mustang 2 11-26-2006 01:15 PM
Flooded Highway = Hydroplane = Water Damage and New Front Bumper Cover Needed kaper232 The Bar 13 07-24-2004 02:50 PM
02:28 PM
