Hurst Short Shifter Install - Mustang Evolution
Old 10-13-2014, 12:59 AM   #1
jedisaias's Avatar
Does anyone have any advice on installing one of these
jedisaias is offline   Reply With Quote
Old 10-13-2014, 02:32 PM   #2
I did mine on a lift which made it a little easier, also i was in the car and my buddy was underneath it. With the two of us it was easier to maneuver it into place and not get caught on stuff. It is a pretty tight fit
Kylar is offline   Reply With Quote
Old 10-13-2014, 08:14 PM   #3
jedisaias's Avatar
Yeah I was thinking of doing it this weekend I might just do it on a couple of stands. It's pretty much a plug and play right?
Old 10-13-2014, 08:23 PM   #4
jedisaias's Avatar
Old 10-13-2014, 08:33 PM   #5
Cbird's Avatar
Region: Iowa
Yeah if you can get the stock shifter off you will have no trouble getting the Hurst on. The only tricky part is the tight fit. I'm a little guy so I had no trouble maneuvering the linkage but if you have bigger hands your gonna get some nice cuts and scrapes
All-in-all it's not to bad. If you can do a cold air intake or a stereo you will have no problems
Oh, and I did mine with just two stands. A lift would of been ideal but I'm just a normal dude and don't have access to that kind of royalty lol
Cbird is offline   Reply With Quote
Old 10-13-2014, 08:35 PM   #6
jedisaias's Avatar
Done both I guess I'll give it a go I'll post pics once I'm done
Old 10-13-2014, 08:54 PM   #7
gqsmash's Avatar
I did it with one jack...lifted the front right wheel up squeezed under and took it apart...15-20 min job
gqsmash is offline   Reply With Quote
Old 10-13-2014, 11:38 PM   #8
Aggiesrok's Avatar
Save the rubber boot under the shifter to block water coming through the floor. It's reused on the Hurst.
Chevy runs deep, don't step in Chevy.
Old 10-15-2014, 02:55 PM   #9
joefez55's Avatar
[QUOTE=Aggiesrok;2106842]Save the rubber boot under the shifter to block water coming through the floor. It's reused on the Hurst.
Good info !
joefez55 is offline   Reply With Quote
Old 10-19-2014, 05:37 PM   #10
jedisaias's Avatar
Any suggestions I'm having a hard time removing the top two 10 mm screws they might be rounded did anyone have similar problems
Hurst Short Shifter jedisaias Mustang DIY and Technical 0 10-13-2014 12:48 AM
For Sale: FOR SALE: Hurst Black Shift Ball / No Hurst Script MELLOWYELLOW06 Mustang Parts for Sale and Wanted 0 01-30-2014 07:13 PM
Steeda short shifter vs hurst badsheep5.0 1979-1995 Mustang GT 36 08-13-2013 01:33 PM
shifter linkage on a toploader with hurst shifter gardgriff24 Classic Mustangs 7 03-02-2009 10:34 PM
Hurst short throw shifter Blue232 Pre-2005 V6 Mustang 3 10-11-2003 11:07 PM
11:37 PM
