New Cam Suggestions - Mustang Evolution
Old 10-27-2014, 05:15 PM   #1
32GT32's Avatar
New Cam Suggestions
What going on guys well the worst thing happen to me that could ever happen to a car guy the motor blew haven't tooken it apart yet but if it's bad it's gonna be a long wait and why not go big or go home right I was just wondering what are the most aggressive cams on the market most hp and torque gain for my 3v I have the frrp cams I love the idle and all but I wanna try something diffrent let me know what yall think
32GT32 is offline   Reply With Quote
Old 10-27-2014, 05:32 PM   #2
Comp cams muthr thumpr
Old 10-27-2014, 05:33 PM   #3
32GT32's Avatar
Give me the most power?
Old 10-27-2014, 05:33 PM   #4
Rapinator126's Avatar
Go with a custom grind cam, or any cam that requires a aftermarket set of valve springs
Old 10-27-2014, 06:11 PM   #5
silvr002001's Avatar
What were you doin when it let go?
Tvs 2300/ 452rwhp 416rwtq
silvr002001 is offline   Reply With Quote
Old 10-27-2014, 06:59 PM   #6
Raeko's Avatar
Agreed either go custom grind or with comp cams 127550. SPR blower cams if you are looking for aggressive And the most power
Raeko is offline   Reply With Quote
Old 10-27-2014, 07:01 PM   #7
If you don't need to replace the valve springs then its not aggressive enough. And i concur with custom grind cams. They are usually the same price as shelf cams anyway.
Old 10-27-2014, 07:03 PM   #8
Raeko's Avatar
By the way the spr cams require you not only to replace the springs but the retainers and also run limiters or lock out your vct depending on how far you want to go. You will get the most out of those cams and you may want to stay clear of the 127650's as they will be too radical
Old 10-28-2014, 08:54 AM   #9
32GT32's Avatar
I wasn't doing anything I was just on the hwy did get it dyno tuned a week before though I got off the hwy on my way to college and the car just started bogging and making weird noises no knocking and it just turned off wouldn't crank or nothing
Old 10-28-2014, 10:52 AM   #10
Damn that's sucks and seems odd. I'm not blaming anyone but if you had it dyno tuned a week prior, the car should have been running perfect. Have you talked to your tuner about it? What were the mods on the engine when it gave out? Best of luck to you though getting her fixed. How many miles on it?
Old 10-28-2014, 11:36 AM   #11
32GT32's Avatar
Yeah my mechanic was thinking the tuner might of been a lil too agreesive on the timing or something the car has Jba long tubes jba offroad h pipe pypes bomb axle back frrp manifold Frpp cams jlt series 3 cai 3.73 gears pretty much full bolt ons and I had just put 100 shot nitrous outlet plate kit when the motor blew it was on the all motor tune even after I got it tuned I hadn't sprayed the car but the car was shifting at 7k I read that the cams I had could only hold up to 6800 on the stock valvetarain in which I didn't replace anything just dropped em in so idk man the car had just hot 64k miles haven't talked to the tuner yet
Old 10-28-2014, 11:45 AM   #12
7k shifting certainly didn't help.
Old 10-28-2014, 11:55 AM   #13
32GT32's Avatar
Yeah and idk it's just alot of things occurred too it was reading cylinder 4 and 8 misfire before it went out so I switched the plugs back to motorcraft since I was running the 0 degree plugs kuz of the nitrous and when I did that nothing changed still had the same code so that same day the motor blew I was gonna buy another set of plugs but it just gave out
Old 10-28-2014, 05:47 PM   #14
BaSohol's Avatar
Misfire codes, I wonder if something happened to the timing chain or VCT
Sent from my SAMSUNG-SM-N900A using Mustang Evolution mobile app
2007 Ford Mustang GT 5spd
Old 10-28-2014, 06:23 PM   #15
32GT32's Avatar
Idk man its one of those things I guess I will never know just make assumptions I guess right that's all I can think of being too agreesive with the timing on the tune kuz it was running for quite sometime on a bama email tune for about I wanna say 6 months
Old 10-28-2014, 06:28 PM   #16
So what made you assume the motor went boom then? Bc guarantee you it did not
Old 10-28-2014, 06:30 PM   #17
32GT32's Avatar
The crank won't turn I got out of the car there was oil down by my tires towed it home took the cai out and there was oil and water the car won't crank I guess the motor locked right?
Old 10-28-2014, 06:35 PM   #18
Do you have a oil pressure gauge?
If so what did it do when it happened?
Check the dip stick what does it look like?
Old 10-28-2014, 06:41 PM   #19
32GT32's Avatar
I'm not sure what the gauge is on the odometer it's a 2010 I think it's oil pressure but I wasn't looking as soon as I got off the hwy it just bogged and gave out idk how else to say it kuz that's what it did I think my mechanic has checked the dip stick I haven't had time to go see what's going on since I go to college
Old 10-28-2014, 07:08 PM   #20
MarkH's Avatar
Region: New Hampshire
Don't sound too good, just drop in a new forged block and go big hp
MarkH is offline   Reply With Quote
Old 10-28-2014, 07:15 PM   #21
32GT32's Avatar
Idk man its kinda hard kuz I'm in college and my plans were to save up for a 2015 or newer model down the road but this happened
Old 10-29-2014, 11:58 PM   #22
32GT32's Avatar
My dad even took it to ford after I told him that the motor was locked but no "I'm a dumbass" and sure enough I go to pick up my car the next day and what do they tell him the same thing I told him so there goes 240$ out of my pocket not his
Old 11-04-2014, 06:05 AM   #23
Frpp hot rod cams they make the most power pound for pound you don't even need to replace the springs call dallas mustang ask for archie. He's the service manager. Ask him
Sent from my SM-N900V using Mustang Evolution mobile app
dude0715 is offline   Reply With Quote
Cam suggestions Ninethourpm Pre-2005 V6 Mustang 38 01-25-2009 07:47 PM
3.8 V6 Comp Cam Performance Cam nmaraijko Mustang Parts for Sale and Wanted 0 11-15-2006 07:11 AM
Suggestions on a new car canman The Bar 27 06-23-2005 08:23 PM
Cam Cores needed for RDMotorsport cam GP RGR Mustang Parts for Sale and Wanted 3 03-05-2005 05:53 AM
02:39 AM
