Either everyone in my town speeds or there is something wrong - Mustang Evolution
Old 10-29-2014, 09:23 PM   #1
509pony's Avatar
So im driving on the hyw today going about 76 on a 70 and I noticed alot of people passing me it feels like im going slow but as soon as I reach 80 then I start passing them. So is there some thing wrong with my stang?
Sent from my SGH-T999L using Mustang Evolution mobile app
509pony is offline   Reply With Quote
Old 10-29-2014, 10:32 PM   #2
Cbird's Avatar
Region: Iowa
Two things I use to check my speedo. One is find one of those "check your speed" things the cops put out. Very common in my area.
Second is a gps or even a gps app on your phone like google maps. When using this method make sure you set the cruise control and maintain a constant speed so it can take a accurate reading.
Cbird is offline   Reply With Quote
Old 10-29-2014, 10:33 PM   #3
509pony's Avatar
Ill have to try that.
Old 10-29-2014, 11:49 PM   #4
Cbird's Avatar
Region: Iowa
Let me know what you find out. If it is off we can help you with that too!
Old 10-29-2014, 11:52 PM   #5
Come to California. You can be speeding on the highway and cops will pass you. If you don't go 80 on the highway you are getting passed left and right. And that is technically 10-15 over
Old 10-29-2014, 11:59 PM   #6
509pony's Avatar
Ill have to find one of does radars and ill update you guys.
Oh i know i was born and raised in socal before i moved to wa.
Sent from my SM-T217S using Mustang Evolution mobile app
Old 10-30-2014, 07:47 AM   #7
Same in parts of VA.
Old 11-03-2014, 09:26 AM   #8
509pony's Avatar
Ok guys car is going 5-6 miles slower
Old 11-03-2014, 10:27 AM   #9
509pony's Avatar
How do I fix it?
Old 11-03-2014, 10:33 AM   #10
Ross2010's Avatar
If you are running larger tires you might need to either request a new tune to compensate for the wheel size or you can add the change while uploading a tune to your car.
Ross2010 is offline   Reply With Quote
Old 11-03-2014, 10:36 AM   #11
509pony's Avatar
Its the stock 17" on it
---------- Post added at 04:36 PM ---------- Previous post was at 04:36 PM ----------
Tires are pretty worn will that cause tge issue?
Old 11-03-2014, 10:37 AM   #12
Ross2010's Avatar
That's weird then.
Old 11-03-2014, 11:30 AM   #13
Having the wrong gear ratio in your tune can also throw off your speedo
Sent from my SAMSUNG-SM-G900A using Mustang Evolution mobile app
mikepolyak is offline   Reply With Quote
Old 11-03-2014, 11:32 AM   #14
509pony's Avatar
Ok so stock tire size is 235/55 I have 245/45 im guessing yhat maybe the issue?
Old 11-03-2014, 12:21 PM   #15
Cbird's Avatar
Region: Iowa
Yeah that's likely your issue. Now is a good time to pick up a tuner and some bama tunes If you haven't already. If you already have a tuner you can just plug in the correct tire size yourself and you're good to go.
You do want to fix it though because you are artificially putting more miles on your car than you should be so its depreciating faster.
Old 11-03-2014, 12:47 PM   #16
509pony's Avatar
Ok I think ill get new wheels and tires and have it tuned 18/9-18/10 on tge back what would be a good size tire for them
Old 11-03-2014, 01:02 PM   #17
509pony's Avatar
I just talked to tge local "mustang" guye wants to charge me 350 to tune my car I told him I can just buy the tuner for 500 lol
Old 11-04-2014, 06:40 PM   #18
Ross2010's Avatar
Good call!
Old 11-05-2014, 09:39 PM   #19
You are running SN95 diameter tires on your S197... probably looks funky and yes, will throw off your speedo. Correct diameter is 27" vs the 25.7" you are running now. Honestly I'd get the right tires instead of tuning for a bad tire size for your car especially if the ones on there are worn anyway.
2000 Mustang GT Steeda #0048
Old 11-06-2014, 07:30 AM   #20
509pony's Avatar
Yea im guessing the guy who owned the car before me didnt know what he was doing when he got does tires
Old 11-11-2014, 02:36 PM   #21
509pony's Avatar
Can I do 245/55/17 or 24/50/17 what out haVing that same problem?
Old 11-11-2014, 02:45 PM   #22
1 - You have 18" wheels so no
2 - 245/45/17 is a SN95 size
27" diameter is stock for a 05-up car. SN95s had 25.7 or 26.1"
Old 11-11-2014, 02:54 PM   #23
509pony's Avatar
It has 17" on it discount ture said I could run 245/50 with out a prob
---------- Post added at 08:54 PM ---------- Previous post was at 08:53 PM ----------
But im not to sure I dont want to buy new tires abd have the save prob
Old 11-11-2014, 03:06 PM   #24
Get on one of the various tire sites and get a size that is at or close to stock diameter. You CAN run a 245/50/17 but it'll be 26.3"...
For a 17" tire you want 235/55/17s on a S197 provided you don't have wider than a 8" rim. Stock diameter for 05-up is 27" like I said. Tirerack will tell you exactly all the specs of any tire you are looking at.
Old 11-11-2014, 03:12 PM   #25
509pony's Avatar
What's the widest I can go on stock bullitt wheels you know?
Old 11-11-2014, 03:18 PM   #26
Wider does not=better but not sure what the stock bullitts were width wise. I'm assuming 17x7.5 and in this case I would just get the 235/55/17s. I would not do wider than a 255/50/17 which is 27.1" and Tirerack has Kuhmo Ecstas in this size and that's the only brand. $140 per tire. The 235/55/17s come in brands that are half that price lol.
Again, that is assuming it is a 17x7.5" wheel.
Old 11-11-2014, 03:23 PM   #27
509pony's Avatar
Ok thanks for the info I think ill be replacing my wheels before I get a tunner
Old 11-11-2014, 03:27 PM   #28
509pony's Avatar
Do I have to tune the car after changing tire or do you think it will be back to normal?
Old 11-11-2014, 04:07 PM   #29
bigmac3's Avatar
This solved a problem the other day, let's try it again. Use this calculator to see what you need. If you are running 17" wheels on a V6, stock tire size is 225/60-17, at least it was on mine. Go from there.
Tire Size Calculator
Frank
1989 Blue LX Hatchback
2001 Red SVT Cobra Convertible (Phoenix)
2002 Black/Red GT (Ginger)
2011 Red Candy Metallic V6 (Manfred)
2016 Magnetic Metallic GT (Susie II)
bigmac3 is offline   Reply With Quote
Old 11-11-2014, 04:46 PM   #30
509pony's Avatar
I know it needs 235/55/17 im just curious if I could go to 245/55/17 or 245/50/17 and fix the problem or would I still need to tune it or get the 235/55/17
Old 11-11-2014, 04:55 PM   #31
bigmac3's Avatar
OK, I used the calculator that I recommended and determined that you are reading fast because your tires are too short. In other words your tires are spinning faster and causing you to get a fast reading which makes it seem like everyone is really running fast but they aren't. Going back to the 235-55-17s should solve your problem. Any rear tire that is 27 inches tall will give you the same results...use the calculator!
Frank
Old 11-11-2014, 05:08 PM   #32
509pony's Avatar
I tried I just had no clue what I was reading lol so tge 245/55 or 235/55 will do the job then!
Old 11-11-2014, 07:13 PM   #33
509pony's Avatar
So I went wIth 245/55 in the back & 245/50 in the front hope that works
Old 11-11-2014, 07:58 PM   #34
Seriously? No... you went way too big in the back and way too short in the front... You are 27.6" out back and 26.3" up front. Your ABS light will likely come on with more than a 1" difference in diameters as well.
I suppose you can lead a horse to water...
Old 11-11-2014, 08:08 PM   #35
509pony's Avatar
Hmm well the speedometer is back to normal and abs hasnt came on
Cant decide either :P 2002VertGT 1996-2004 Mustang GT 5 04-23-2012 12:23 AM
...Blow it or stroke it, either way im in a good place!!! Mikes347 General Mustang Discussion 64 01-24-2011 08:42 PM
Any body know why everyone has either a 2010 Mustang GT or an Honda Accord? tobias General Car Discussion 1 03-18-2010 07:25 PM
What car would you rather have if you could have either??? 1965 Ford Mustang or 1963 Mercury Comet? colton Classic Mustangs 3 08-29-2009 01:40 PM
There is something very wrong about this site n8r The Bar 28 05-07-2006 02:36 PM
04:14 PM
