Code P0153 - Mustang Evolution
Old 11-01-2014, 12:58 PM   #1
Cbird's Avatar
Region: Iowa
Code P0153
Got the code a few months ago, deleted it and waited for it to come back and it did. Research shows it's most common with longtubes but I don't have longtubes.
What's my best plan of attack? The code isn't very clear on what the problem really is.
P0153: Oxygen Sensor Circuit Slow Response (Bank2, Sensor1)
The code came on shortly after starting the car and driving away, it didn't come on in the middle of a drive.
Cbird is offline   Reply With Quote
Old 11-01-2014, 03:13 PM   #2
Cbird's Avatar
Region: Iowa
Having some trouble getting the driver side oxygen sensor off. Any advice?
Old 11-01-2014, 03:40 PM   #3
Ross2010's Avatar
Are you running a tune or recently done any exhaust work?
Ross2010 is offline   Reply With Quote
Old 11-01-2014, 03:48 PM   #4
jedisaias's Avatar
I got a similar code once I cleaned the TB and problem solved
jedisaias is offline   Reply With Quote
Old 11-01-2014, 03:51 PM   #5
Ross2010's Avatar
I ask because I got that same code after installed my shorty headers and high flow cats. All it needed to fix it was to be retuned. I'd hold off on replacing your O2 sensor and see if it's possibly a tune issue, unless your have a lot of miles and are due for new ones.
Old 11-01-2014, 03:58 PM   #6
Cbird's Avatar
Region: Iowa
Umm I did recently install an X pipe but the check engine first came on first before the install.
Could be an exhaust leak I've read.
I was able to change the passenger side 02 but still hung up on the driver side. I bought two different style 02 sensor sockets and everything. What a bad location.. Anyway I'm afraid of running a brand new 02 and one with 85k on the other side ya know?
Ordered a can of throttle body and maf cleaner. Also a new air filter. I'll be doing that.
Old 11-01-2014, 04:06 PM   #7
jedisaias's Avatar
Yeah I'm sure with a good cleaning and updated tune you can get rid of that code. Good Luck
Old 11-01-2014, 04:57 PM   #8
Cbird's Avatar
Region: Iowa
I sure hope so. Do you think I'm good to run a new oxygen sensor with an old? Not only that but one is NGk and the old one is motorcraft. If not, hopefully it's fine to drive it to the mechanic. I can't get it off to save my life lol.
FORD MUSTANG BRAINIACS what does r-code and/or c-code mean? kele74 Classic Mustangs 4 03-16-2010 05:12 PM
CEL code P1131? candmforever Pre-2005 V6 Mustang 20 09-15-2009 10:47 PM
autozone won't pull my cel code!? candmforever Pre-2005 V6 Mustang 8 12-10-2003 09:19 PM
ECU code FA23...sound right? MUSTANGJUNKY420 Pre-2005 V6 Mustang 6 08-11-2003 04:35 PM
paint code for my car... dark Mustang Audio & Video 1 08-01-2003 03:14 PM
04:46 AM
