air con climate control not working - Mustang Evolution
Old 11-05-2014, 06:32 PM   #1
Elvira's Avatar
Region: Australia
Send a message via Yahoo to Elvira
Red face air con climate control not working
To whom it may concern
I have a 2010 Mustang Gt Coupe.
My air con decided to not work, just hot air coming .
Maybe some had this problem.
I have a booking with a air con specialist, but maybe there are some tips, from some body in the community, had the same problem.
Thank you in advance
Cheers
Elvira
Richmond Victoria
Australia
Elvira is offline   Reply With Quote
Old 11-06-2014, 02:15 AM   #2
natestang07's Avatar
Posted in the wrong section but sounds like your ac needs to be recharged. No big deal
05 Gt Premium Performance White, flowmaster outlaws, Jlt Series 3, Bama 91r tune
Old 11-06-2014, 04:56 AM   #3
bucko's Avatar
The A/C specialist will check for a freon leak. This will determine the extent of your repair. If the leak is a hose or a fitting, the cost will be much less then if the leak were coming from the evaporator, the condensor, or the A/C compressor. In any event, a leak should be fixed. Adding freon occasionally will get the system to blow cold air, but will only leak out again. If it's a slow leak, perhaps charging the system (adding freon) will work for 2 days, 2 weeks, 2 months, or perhaps longer. The specialist you took it to will tell you, but its best to simply repair the component that's leaking.
They will want to replace the dryer in most cases when working on an A/C system; the dryer removes moisture from the A/C system, and a leak can draw in moisture from the outside air, and damage the A/C compressor, a reason why you want to identify and repair the leak.
To learn on how an automobile A/C system works and their components, google "automotive A/C". You will find good articles and write ups on how they work, and good descriptions on their components.
keep us posted as to your findings. Good luck!
Old 11-06-2014, 05:22 AM   #4
Elvira's Avatar
Region: Australia
Thank you
Thank you all,what gave me some answers to my air con not working.
See what the results are tomorrow when the air con guy has checked.
Hopefully nothing serious as the heather seems to work& fans going.
Will keep you posted .
Thanks again heaps.
Cheers
Elvira
Richmond
Australia
Black Beauty 2010 GT Premium
Old 11-07-2014, 03:20 PM   #5
Elvira's Avatar
Region: Australia
Hi To every one gave some advise, I had low gas in my air con, also apparently air con should have service done every two years. Did no know that learned something. its working a treat again.
Thanks again
Cheers
Elvira
Black Beauty
Melbourne
Australia
92 GT Climate control not working Fymihwd 1979-1995 Mustang GT 0 02-14-2014 02:44 PM
Removing/Installing Climate Control Knobs in a 2006 w/ Shaker 500 DAG 01 2005-2010 V6 Mustang 0 01-08-2013 01:55 PM
Where to find the sticker that goes behind the climate control knobs? aodha 1979-1995 Mustang GT 4 12-17-2011 08:48 AM
How do the climate control levers work on a 1965 ford mustang? meturato Classic Mustangs 1 08-18-2009 09:28 PM
Climate Control System Not Working mach232 Pre-2005 V6 Mustang 9 12-15-2004 07:33 PM
10:27 AM
