Help oil leak - Mustang Evolution
Old 11-13-2014, 09:21 AM   #1
509pony's Avatar
Help oil leak
I bought my used with 90k its an 06 but it seems every time I fix a problem with it another comes up long story short now I have an oil leak just saw it today I don't know how long its been going but its a pretty small leak on the driver side ill put more Info once I have it but mean while any suggestions would be appreciated.
Sent from my SGH-T999L using Mustang Evolution mobile app
509pony is offline   Reply With Quote
Old 11-13-2014, 10:25 AM   #2
509pony's Avatar
Im pretty sure it only leaks after the engine has been running
Old 11-13-2014, 12:05 PM   #3
Cbird's Avatar
Region: Iowa
Well if you can get under the car with it running you can probably see where it's leaking from.
When I was changing my oil once the old from the old filter stuck on the car and I didn't catch it. After I installed the new filter it would leak pretty good. Doubt that's your issue but maybe
Cbird is offline   Reply With Quote
Old 11-13-2014, 12:08 PM   #4
natestang07's Avatar
Well oil is thinner when it is warm so only leaking when car is warm is very possible. Could put it up on jack stands and let it run
05 Gt Premium Performance White, flowmaster outlaws, Jlt Series 3, Bama 91r tune
Old 11-13-2014, 12:23 PM   #5
509pony's Avatar
It seems like its just one or two tiny drops but just knowing is driving me crazy. Ill have to put it on the car lift later is there some type of dye I can use to trace it?
Old 11-13-2014, 12:39 PM   #6
Cbird's Avatar
Region: Iowa
Yeah you can use some dye stuff that reacts to UV Light but you will probably be able to see where it's leaking from after a drive
Old 11-13-2014, 12:41 PM   #7
509pony's Avatar
Ill check out tonight see if I can pin point where its coming from
Old 11-13-2014, 07:41 PM   #8
509pony's Avatar
So I check the car its not leaking oil its leaking transmission fluid out of a sensor does anyone has an idea what it can be
Old 11-15-2014, 08:46 AM   #9
Travis238's Avatar
O-ring on the sensor or a cracked sensor.
2005 Roush GT, Roush cai, BAMA 93r tune
Travis238 is offline   Reply With Quote
Old 11-15-2014, 10:03 AM   #10
509pony's Avatar
Would that be the speed sensor
Old 11-15-2014, 10:47 AM   #11
Travis238's Avatar
Help oil leak
Were is the sensor located at on the trans.
Old 11-15-2014, 11:50 AM   #12
509pony's Avatar
Its on the fron right side underneath the tranny
Old 11-15-2014, 12:57 PM   #13
Travis238's Avatar
Auto or man
Old 11-15-2014, 01:46 PM   #14
509pony's Avatar
Manual
Old 11-15-2014, 03:02 PM   #15
Travis238's Avatar
Speed sensor is norm close to the back of the trans
Old 11-15-2014, 04:38 PM   #16
509pony's Avatar
If it is the speed sensor os it common to do that and if so can I take it off or will a bunch of tranny fluid spill out?
Old 11-15-2014, 05:59 PM   #17
Travis238's Avatar
It shouldn't leak out that much oil if it's below the fill plug.
Old 11-15-2014, 06:02 PM   #18
509pony's Avatar
Its not alot just a small drop
Old 11-15-2014, 06:04 PM   #19
Travis238's Avatar
When u remove the sensor. That's when im referring to.
Old 11-15-2014, 06:27 PM   #20
509pony's Avatar
Ok ill check it out when it warms up a bit and keep you guys posted thanks for the info
Help with oil leak! Mfore33 1996-2004 Mustang GT 0 12-03-2012 09:34 AM
Oil, Oil Additives, Oil Filters, FACTS robb15033 General Mustang Discussion 2 08-02-2012 11:37 AM
small oil leak ??? 96mustangv8 1996-2004 Mustang GT 3 05-16-2011 01:44 PM
2001 Cobra fuel leak (I know wher3e the leak is) badcrc General Mustang Discussion 2 12-27-2008 11:54 PM
oil leak 95blackgt 1979-1995 Mustang GT 6 04-03-2008 09:53 PM
11:56 AM
