Rpm's don't come down, cold start. - Mustang Evolution
Old 11-14-2014, 11:42 AM   #1
Cbird's Avatar
Region: Iowa
Ever since it got cold (~20 degrees F) my car idles at 1500 for a long time.
I understand that the car idles high for a short amount of time, but I waited 10 minutes before I was like "f**k this" and just put it in gear.
Here is where things get interesting, as soon as I throw it and gear and let out the clutch the car idles down to 800 where it should be. It is mocking me..
Do I have to pull the battery and re-learn the idle? If I have to set my 16 band EQ on my stereo again I won't be a happy camper.
Cbird is offline   Reply With Quote
Old 11-14-2014, 11:51 AM   #2
It's either that or skip right to replacing the IAC with a new Motorcraft part. You're going to have to disconnect the battery either way so you may as well try the idle relearn procedure first.
Old 11-14-2014, 12:20 PM   #3
Cbird's Avatar
Region: Iowa
Where is the IAC valve on the 3v? I thought since the throttle was electronic it would just flip it open a bit, eliminating the need for a iac valve.
I notice with the car set to on (not running) I get this really sickly sounding "hum" coming from the throttle body when I push the gas pedal down. Something probably is going out there.
Guess I'll be disconnecting the battery, re-running auto EQ, and then tweaking it again. Bummer.
Old 11-14-2014, 12:33 PM   #4
Lol.
Sorry about that!
You are correct. The whole throttle body needs to be replaced if there is a problem.
I'd definitely try the idle relearn!
Old 11-14-2014, 01:03 PM   #5
Cbird's Avatar
Region: Iowa
Will do! I'll report back after try the relearning process.
Does your tb a pretty nasty sounding hum when you push the pedal down with the key in it?
If my tb is bad it gives me an excuse to go aftermarket, right? :p
Old 11-14-2014, 01:21 PM   #6
I have an 01 so it has a throttle cable.
If it's making a nasty noise that it wasn't making previously, chances are that it is malfunctioning. If so, yes, this will be a perfect time to upgrade!
Old 11-14-2014, 03:00 PM   #7
Cbird's Avatar
Region: Iowa
I can't remember if it was or not. The only reason I ever pushed the pedal down with the car set to on was to clean the throttle body. I couldn't manually move the plates.
Hmmm, after I cleaned the throttle body it started to idle high. I cleaned out a ton of crud. Maybe I do need to relearn.
I have a second. I'm gonna go drive the car to get it up to temp and then do the idle relearn
Old 11-14-2014, 09:54 PM   #8
Cbird's Avatar
Region: Iowa
Yup it worked. Relearned the idle and wouldn't you know it. The rpms drop down with in a minute now.
Throttle body still makes a funky mechanical noise. I expect that to go out on me fairly quickly. No doubt at the worst possible time leaving me stranded somewhere, so I'll be ordering a replacement asap
Old 11-14-2014, 10:02 PM   #9
I know that some people do it a couple of times a year, when the seasons change.
Glad you got it fixed!
Running lean on Cold start in cold temperatures. Zed 2011-2014 Mustang GT 3 09-24-2014 07:23 AM
Welcome to WWP Chaos come check it out we have a stacked card come c the action? jukka General Mustang Discussion 6 03-26-2010 10:04 PM
68 coupe 289 lights come on but won't turn over and headlights won't come on Sixty8 Coupe Classic Mustangs 2 03-07-2009 07:52 PM
fuel pumps don't come on dana 1979-1995 Mustang GT 13 02-24-2006 06:06 PM
Just so you don't think I don't take care of my car.... 97Stallion Pictures and Videos 15 10-10-2004 11:30 PM
04:15 PM
