Pacesetter Long Tube Headers??? - Mustang Evolution
Old 11-16-2014, 11:42 PM   #1
Hello people....so I'm planning on buying long tube headers for my 2006 Mustang GT.
I have been researching for a while and I came across a brand called Pacestter who make long tube black painted headers (no type of coating what so ever)...they are $286. I have seen other ceramic name brands for almost 3 times the price.
My question is : Is pacesetter a good brand? Would it be worth buying them and have them ceramic coated at a shop before I put them in? Or should I go with a "better" brand?
Lastly, what are your guys experiences with long tubes??? Please share your experiences! Thanks a lot!........
Bluerings is offline   Reply With Quote
Old 11-17-2014, 06:22 AM   #2
silvr002001's Avatar
Pacesetter is a economy brand. I had some on an old f body and I never had any issues with them. Decent gains sounded good.
If I were to put headers on my car now I would go with a better brand. Possibly kooks. Just buy them coated rather than going through the trouble of having them done. But have some sort of coating on there either way. The difference in heat from non coated is outrageous
silvr002001 is offline   Reply With Quote
Old 11-17-2014, 09:41 AM   #3
UrMaster's Avatar
Had their armor costed version on 3 different camaros and a Trans am, never had an issue. Good gains and good quality just not over priced like some brands. I would have run them on my coyote if it didn't have Dynatech on it when I got the car.
Sent from my SM-N900V using Mustang Evolution mobile app
2011 GT Premium A6 glass roof.
Dynatech LT's, OR-X, Kooks Axle-back, Circle D 5c, Boss IM, BBK 85mm TB, JLT CAI, BMR LCA's, adj UCA & Panhard,Strange 10 way struts, 331 gears tuned by AED.
UrMaster is offline   Reply With Quote
Old 11-17-2014, 09:56 AM   #4
Ok I see...now what about the sizes of the pipes?? I've seen 1 5/8 and the pacesetter ones I saw where 1 3/4. I guess bigger is better?? How big is the difference in sound and power gains??
Old 11-17-2014, 10:39 AM   #5
UrMaster's Avatar
1 5/8 is more then big enough for a stock n/a 4.6. Bigger isn't always better on primaries! I think you'll actually lose a little mid range and/or low end if you did 1 7/8.
Old 11-17-2014, 08:32 PM   #6
Boosted_3v's Avatar
JBA longtube πŸ‘
Boosted_3v is offline   Reply With Quote
Old 11-18-2014, 08:35 PM   #7
If you buy the pacesetters, you'll be re-buying headers in 2 years. The black paint is there to prevent corrosion while they are in the box, it burns off after your initial start and you have bare aluminized metal headers. Do it once, do it right, you get what you pay for.
Old 11-18-2014, 09:53 PM   #8
UrMaster's Avatar
Can't speak for the painted ones, but I had their coated ones on a car that was daily driven in Chicago winters for 6 years and never had issues.
Old 11-19-2014, 05:14 AM   #9
The Mustang ones are black painted, at least the ones he is talking about for cheap. I had MAC (aluminized) ceramic ones myself on my 95 and they lasted just fine but that wasn't because of the quality of the headers, its because I bought bare ones vs their ****ty MAC coating and had them blasted/coated locally which is always an option.
Old 11-19-2014, 01:25 PM   #10
Thanks for all the info....one more question : If you have long tubes,catted H pipe,cold air intake and an axleback exhaust,what's the approximate HP gain?? I'm just curious...
Old 11-24-2014, 11:11 AM   #11
Zcarmack16's Avatar
You will probably want to get a tune if you want to get more horsepower. You really only get more horse power with the tune and with all those upgrades and a tune about 40 hp. Without a tune I'm not quite sure but it's not much.
Zcarmack16 is offline   Reply With Quote
Old 11-24-2014, 12:11 PM   #12
All that and a tune on a 3V... probably 20rwhp. That is with a real good 93 octane tune and everything else dialed in. I'd recommend a non-canned tune like AED/MPT instead of a canned Bama/Steeda tune.
Old 11-24-2014, 12:49 PM   #13
natestang07's Avatar
Hp guess with same setup and an o/r h pipe?
05 Gt Premium Performance White, flowmaster outlaws, Jlt Series 3, Bama 91r tune
Old 11-24-2014, 01:15 PM   #14
A good set of hi-flow cats will take away like 1hp. Ppl get all bent out of shape talking about "power robbing" converters when really they just don't want to pay the $$$ for a catted pipe. When you start getting over the 500hp mark is when cats start becoming a bit of a bottleneck.
Old 11-24-2014, 01:18 PM   #15
To me when I have been looking around it has never been marginal power loss it has been those damned expensive cats lol
Old 11-24-2014, 01:36 PM   #16
Not to mention that new cars run so clean you can often pass a sniffer with no cats.
Old 11-24-2014, 01:42 PM   #17
My state is communist about guns not cars
Old 11-29-2014, 04:47 PM   #18
mpenny's Avatar
The best bang for the buck is a Tuner with a set of 3.73 or 4.10 gears. Unless you got the bucks to buy a Super Charger. You can spend a bucket load of money on add-on and still not get the seat of the pants feel you'll get with a set of gears.
mpenny is offline   Reply With Quote
Old 12-29-2014, 05:30 PM   #19
Zcarmack16's Avatar
Has anyone installed these? Do you really have to raise the engine and pull the ignition and steering arm?
Old 12-29-2014, 06:55 PM   #20
Boosted_3v's Avatar
It's easy you can raise the motor from the oil pan just put a pice of wood between the oil pan and jack then slowly lift with mount bolts off then un do the steering shaft, un bolt the starter, take off the mounts and jack up the motor, it's easy. Not too hard to install long tubes on a 3v motor.
Old 12-29-2014, 07:14 PM   #21
Zcarmack16's Avatar
How long does it take to do all that? Hard to put everything back together like the steering arm?
Old 12-29-2014, 07:15 PM   #22
Zcarmack16's Avatar
How high does the motor need to go up?
Old 12-29-2014, 07:30 PM   #23
PonyOnTheBeach's Avatar
I've never actually done it, but I believe it's only a few inches.
It's all about the Smiles Per Gallon
PonyOnTheBeach is offline   Reply With Quote
Old 12-29-2014, 08:04 PM   #24
Zcarmack16's Avatar
Will the tranny allow for the engine to be raised that high?
Old 12-29-2014, 08:06 PM   #25
Zcarmack16's Avatar
Old 12-30-2014, 08:41 AM   #26
Boosted_3v's Avatar
Yes it will
For Sale: 05-09 pacesetter long tube headers(brand new) Atrav83 Mustang Parts for Sale and Wanted 10 02-01-2014 12:57 AM
Pacesetter Long tube headers setup arphell 2005-2010 V6 Mustang 5 12-30-2013 08:08 PM
Long tube or short tube headers for acceleration Mustang47 Pre-2005 V6 Mustang 7 10-31-2013 03:41 PM
Are pacesetter long tube headers Fourloko530 Pre-2005 V6 Mustang 15 08-06-2012 11:24 PM
Pacesetter Long Tube Headers 08Mustang 2005-2010 V6 Mustang 4 06-09-2012 01:07 PM
10:05 AM
