Unlock Key- Car Alarm goes off - Mustang Evolution
Old 11-17-2014, 11:08 PM   #1
The battery for my remote unlock does not work at times, I can unlock the car with my key but then the alarm goes off. Does anyone else experience this problem? Fixable? Suggestions?
Thanks!
ctrez06
ctrez06 is offline   Reply With Quote
Old 11-17-2014, 11:37 PM   #2
Gravydog316's Avatar
could be your wiring in your car--even a kink in a wire; your battery in your transmitter not making contact properly; a bad fuse; your car battery dying; electrical interference from something; aliens...
the best thing to do is give the car to me asap
Old 11-17-2014, 11:39 PM   #3
butt seriously, a few times when I unlocked my door lock w/ my transmitter, the trunk lid would pop up, then it stopped... so I dunno...
Old 11-17-2014, 11:50 PM   #4
Thanks for the quick response, I don't care about the transmitter so much cause I can sit there and press it until the door unlocks but the problem I'm more confused about is the car alarm going off when I use my key to unlock the door.
ctrez06
Old 11-18-2014, 12:05 AM   #5
ctrez06
well, with my other car, if you press the Lock button on the transmitter once, the doors lock, then if you use your key & unlock it, the alarm doesn't go off;
BUT, if you press the lock button twice, the first time locks the doors & the second press turns on the alarm, so if i use my key & in the door, & unlock it, the alarm DOES go off & it shuts off when i put my key in the ignition
maybe there is a problem w/ your transmitter or its battery that is causing the alarm to be activated.
Old 11-18-2014, 12:07 AM   #6
have you tried a different battery in your transmitter? it could just be a weak battery
Old 11-18-2014, 12:12 AM   #7
Now that you say that...stuff is starting to make more sense, I hope. Whenever I lock my car normally, it does the triple honk, then a honk like 5 sec after, which I'm assuming is the alarm engaging. This happens automatically every time I use the transmitter. Then when I use my key the alarm goes off.
Tomorrow I will try locking the door from the inside and shutting the door and unlocking with the key. Let the experiments begin!
Thanks for your help!
ctrez06
Old 11-18-2014, 12:15 AM   #8
I have not messed with the transmitter yet. I'm just lazy or cheap I guess haha, I do have a second transmitter that is attached to my spare that works better and still haven't switched them.
ctrez06
Old 11-30-2014, 10:12 AM   #9
hi!!! 😃😃😃
did you find the problem yet? I hope so!! 👍
programming key remotes - changing unlock settings dpevoar 2005-2010 V6 Mustang 3 07-05-2013 10:05 AM
Factory alarm?? Alarm sounding every 30mins joedelpen 2005-2010 V6 Mustang 6 06-28-2013 02:00 PM
Program key to unlock both doors with one click? Jukens 2011-2014 Mustang GT 13 05-31-2012 12:10 PM
2010 GT Car Alarm Goes Off Unexpectedly tsgs 2011-2014 Mustang GT 8 06-03-2011 08:38 AM
Wanna Unlock your car Use a Tennis Ball bluemustang Pictures and Videos 25 02-07-2007 09:56 AM
10:18 PM
