Best drag shocks - Mustang Evolution
Old 11-21-2014, 10:23 PM   #1
larrysgt's Avatar
Best drag shocks
Looking at 90/10 n 50/50 lakewoods.
What are you guys running
larrysgt is offline   Reply With Quote
Old 11-28-2014, 06:32 PM   #2
lindertw's Avatar
strange single adjustable front struts/rear shocks, cobra jet drag springs, metco UCA/LCA, bmr relocation brackets. 302rwhp, 3490 lbs, low 12's with 1.5x 60' times... (more details)
2005 GT, N/A 302rwhp/317rwtq, 3500 lbs
12.095 @ 111.08, 1.576 60'
lindertw is offline   Reply With Quote
Old 11-28-2014, 10:55 PM   #3
Sirtat's Avatar
vi-king double adjustable shocks are the absolute best shock and a great price compared to any other adjustable shock
IBLT IT
2005 Promar Performance forged long block
Kenne Bell 2.8L LC mammoth supercherger
and and and I DRIVE IT LIKE I STOLE IT !!!!
http://www.youtube.com/watch?v=_K_QJ...ure=plcp<br />http://www.youtube.com/watch?v=NWfvYVYlfio&feature=plcp
Sirtat is offline   Reply With Quote
Old 12-01-2014, 10:54 AM   #4
larrysgt's Avatar
Dang that's badass. Shocks look good with that launch. I wana try them out.
Hey I have LCA with relocation bracket but it's non adjustable.
Would it still benefit if I get non adjustable UCA for my launches?
Old 12-01-2014, 11:59 AM   #5
lindertw's Avatar
My LCA's are fixed length, I think you'll be fine. I would recommend getting an adjustable UCA (and mount with multiple mounting holes). Being able to adjust the UCA length will help set your pinion angle, and the additional holes on the UCA mount will help dial in the instant center/anti-squat.
A fixed length UCA with poly bushings will be better than the OEM piece with soft rubber bushings, but the lack of adjustment means you won't be able to dial everything in...
good luck...
Old 12-01-2014, 12:02 PM   #6
larrysgt's Avatar
good luck...
Thanks
Old 12-01-2014, 12:24 PM   #7
Rapinator126's Avatar
verry impressive times for 300hp at the ground
Old 12-01-2014, 04:11 PM   #8
lindertw's Avatar
thanks man - hoping a gear swap this winter will help me squeak into the 11's in the spring. We are lucky out this way to have great track prep and excellent DA
Old 12-01-2014, 05:34 PM   #9
You going to go with 4.30's or 4.56? Assuming your going lower.
Old 12-01-2014, 06:25 PM   #10
lindertw's Avatar
4.56's
Old 12-01-2014, 06:31 PM   #11
I want to see that thing launch with the 4.56's. Thinking about doing anything else with it? Maybe cams or a bottle?
Old 12-01-2014, 07:03 PM   #12
lindertw's Avatar
no plans for cams or nitrous, but I'd like to pull a bit more weight out of it.
Old 12-01-2014, 07:11 PM   #13
Is it a street car at all?
Old 12-01-2014, 08:02 PM   #14
lindertw's Avatar
yep - I swap the drag tires and pull the passenger seat when I hit the track, otherwise street car. Passes VA emissions and driven when the weather is nice (under a car cover at the moment).
Old 12-13-2014, 02:48 PM   #15
larrysgt's Avatar
Hey do you suggest getting 15x10 rears or 15x8's?
---------- Post added at 03:48 PM ---------- Previous post was at 03:47 PM ----------
I have power I just can't put it down. Building suspension in winter
Old 12-15-2014, 06:26 PM   #16
lindertw's Avatar
15x10's = greater tire selection. I went with 15x8 to minimize rotational weight as much as possible (every little bit helps with my low power).
If you go the 15x10 route you'll need a swaybar relocation kit so the rim will clear the shock mount. What are the suspension plans for the winter?
Old 12-17-2014, 10:46 PM   #17
larrysgt's Avatar
Hm that makes more sense.
I'm doing a Bmr tubalar k member & radiator support with sway bar delete. The 13 cobra jet springs
And I'll try those shocks n struts from up there^^^
And last is gana be tire n wheel set up. I was looking at either race stars or sve drag wheels.
Old 12-17-2014, 10:52 PM   #18
larrysgt's Avatar
That instructional vid by cj pony was the worst lol
I didn't really get it.
---------- Post added at 11:52 PM ---------- Previous post was at 11:52 PM ----------
Like the installation
Drag shocks and struts vs high stall torque converter Luna1994 General Mustang Discussion 5 05-06-2014 06:30 PM
Best and well priced shocks and struts 98mustang11 Pre-2005 V6 Mustang 150 03-06-2013 12:42 PM
Drag bash london drag strip in ky. This sunday 4/29/12 H.A.W.K At the Track 1 04-30-2012 01:37 AM
Best shocks and struts for lowering? Blackedout Pre-2005 V6 Mustang 17 12-05-2011 07:57 AM
Best shocks and struts for lowered stang. powerstroker Pre-2005 V6 Mustang 5 05-27-2009 12:12 AM
08:14 AM
