Hood flutter normal - Mustang Evolution
Old 11-25-2014, 01:50 PM   #1
Hood flutter normal
Hello,
Im not sure if it is normal that the hood flutters and lifts a bit.
It starts ar approx. 120mph on the german autobahn It scares me a bit since you can clearly see the hood shaking because of the wind.
Can it bend or fly off or cause any other damage? Or is it normal...
My 2005 GT is stock
Viking05 is offline   Reply With Quote
Old 11-25-2014, 02:12 PM   #2
Zcarmack16's Avatar
Your hood is shut all the way and not just on the emergency latch correct? My hood doesn't flutter or lift at that speed. Your latch might need replaced so it is a tighter fit and won't lift or flutter.
Zcarmack16 is offline   Reply With Quote
Old 11-25-2014, 02:17 PM   #3
i thought it's because of the bad aerodynamics of the mustang, especially because the hood overlaps a bit.
It's closed and there are no issues at 100mph.
How could this only be my car?? Your hood isn't shaking at all?
Old 11-25-2014, 03:39 PM   #4
dave73's Avatar
I don't think the aerodynamics of the Mustang are THAT bad. My mustang hood does not shake at 120 but I don't regularly travel at those speeds either. I would if I could though and it's probably a good thing I can't. What's the fastest you've had it on the Autobahn?
dave73 is offline   Reply With Quote
Old 11-25-2014, 03:42 PM   #5
Zcarmack16's Avatar
It's just the speed difference. My car doesn't do it at all. It has to do with your latch or something along those lines. I don't think it is the aerodynamics of the mustang.
Old 11-25-2014, 03:50 PM   #6
bigmac3's Avatar
Easy, your hood latch probably just needs to be adjusted. You've simply never noticed it at lower speeds. If it is a major concern, install a set of hood pins.
Frank
1989 Blue LX Hatchback
2001 Red SVT Cobra Convertible (Phoenix)
2002 Black/Red GT (Ginger)
2011 Red Candy Metallic V6 (Manfred)
2016 Magnetic Metallic GT (Susie II)
bigmac3 is offline   Reply With Quote
Old 11-25-2014, 03:55 PM   #7
dave73's Avatar
I like the hood pin idea that would probably offer some piece of mind on the Autobahn. Could see where worrying about the hood smashing into your windshield could be a concern at 140!
Old 11-25-2014, 05:43 PM   #8
Zcarmack16's Avatar
Good pins is a good idea. Also look into a new latch.
Old 11-25-2014, 10:38 PM   #9
Aggiesrok's Avatar
My 07 does have a little flutter over 110, but it did that when it was brand new.
I don't thinking would fly up with the center latch secured.
Hood pins are peace of mind and look cool.
Chevy runs deep, don't step in Chevy.
Old 11-25-2014, 11:40 PM   #10
I've have been on the autobahn only once, since i live in switzerland not in germany. but i looks like I'll go there more often now since it's fun to drive.
And on that one time i did once 138mph but it was going downwards
Old 11-25-2014, 11:44 PM   #11
This sounds more similar to my driving experience. It also started at around 110, and then with the speed increasing the shaking also increased (not very concerning, but i still clearly noticed it)
It could be that my mustang is model year 06, im not sure but the dealer told me. for sure it was on the road first in 2005.
and somewhere i read the hood fluttering is the worst on 06 and 07 stangs
Old 11-26-2014, 07:37 AM   #12
It is more or less normal but you can simply adjust the bump stops up to get it to stop. My Bullitt did it closer to 100mph, adjusted stops and went away. Haven't noticed if the '10 does or not.
2010 Sterling Grey Premium GT 3.73 axle 5spd
FRPP Cams, intake, TB and CAI
BBK LT headers, fuel rail and UD pullies
Hurst Shifter
Lowered with upgraded rear suspension
Galaxie64 is offline   Reply With Quote
Hood flutter dwlow09 2011-2014 Mustang GT 9 11-26-2013 10:35 AM
Front end vibration & hood flutter 2013Coyote5.0 2011-2014 Mustang GT 12 10-20-2013 08:27 PM
normal fox? oaktonarcher 1979-1995 Mustang GT 9 12-29-2005 04:57 PM
Loose clutch & Ford says it's normal WhiteThang Pre-2005 V6 Mustang 5 02-21-2005 10:27 PM
Are these normal 1/4 times? MonteCitan 1996-2004 Mustang GT 13 12-11-2004 06:40 PM
02:18 AM
