Tranny oil change - Mustang Evolution
Old 11-30-2014, 01:15 AM   #1
Boosted_3v's Avatar
Tranny oil change
Anyone have a wright up on how to do this and how much oil it takes? How hard is it to do?
Boosted_3v is offline   Reply With Quote
Old 11-30-2014, 02:14 AM   #2
natestang07's Avatar
Not sure how much fluid can find that easy enough online but go down through the shift er with a rubber hose and that is the easiest way.
05 Gt Premium Performance White, flowmaster outlaws, Jlt Series 3, Bama 91r tune
Old 11-30-2014, 09:55 AM   #3
Boosted_3v's Avatar
Just undo the drain plug right because some guy say oil change and some say compleat oil "flush"
Old 11-30-2014, 01:43 PM   #4
Oil drain is fine
Old 12-02-2014, 11:31 AM   #5
Oil Change Guide I used
I recently changed the oil in my transmission using this guide from "Moosestang" at mustangforums.com.
A How To: changing manual transmission fluid - MustangForums.com
(I hope it is OK to post a link to another forum. I didn't see any provision against it in forum rules.)
It wasn't too difficult, and I agree that going through the shifter tunnel with a rubber tube was easy to do.
I put the car up on ramps and jack stands to get it level, but the car was warm when I opened the fill plug. I don't know if the transmission was over-filled by the quickie lube place or if the fluid just expanded significantly because it was warm, but a significant amount of fluid came out from the filler hole. I was not prepared for that and made a big mess - you may have a better experience, but you've been warned
Other than getting hot transmission fluid everywhere when opening the fill plug, the fluid change was easy.
Specification calls for 3.2 quarts which should put the level about 1/2 inch below the fill plug. I used 3 quarts and the level felt right so I stopped there as I was frustrated that it had been overfilled before. I'll probably go back and add another .2 quarts soon though.
Speewack is offline   Reply With Quote
Old 12-02-2014, 01:35 PM   #6
Boosted_3v's Avatar
Sweet thanks man that helps out a lot!!!
Old 12-02-2014, 09:49 PM   #7
3650s love Pennzoil synchromesh and its only $8/bottle at auto zone. Butter shifts, no issues at 6k. Mine was a fresh rebuild tho.
Sent from my VS980 4G using Mustang Evolution mobile app
Old 12-02-2014, 10:44 PM   #8
Boosted_3v's Avatar
I have a bottle of RP laying around that I used on my 2v think I'm just going to by RP
Old 12-03-2014, 12:16 AM   #9
Tremec actually recommends to NOT use Royal Purple. There are chemicals in it they use that destroy synchros.
You want Pennzoil Synchromesh. It is like holy water for the 3650.
Old 12-03-2014, 04:59 AM   #10
bucko's Avatar
Pay about $165.00 every 30K for a complete oil change (flush) and be done with it. While it's good to drop the automatic transmission pan to change it's filter, getting only about 3.2 quarts of fresh fluid makes no sence to me. The torque convertor holds much more than this, so as soon as you start the car, you've mixed 3 quarts of fresh into about 6 quarts of old. A true flush done every 30K will assure you of a long lasting automatic transmission.
The myths of flushing causing damage to an older transmission are just that; myths. The new flushing systems used today connect to the send/return lines of the automatic transmission lines that connect to the radiator (for fluid cooling), and use no pressure (or low) to remove the old fluid and replace with fresh. Pluse, they drop the pan and replace the filter.
Paying this amount every 30K miles is soooo much better than a replacement transmission down the road.
Old 12-03-2014, 05:47 AM   #11
fenixignition's Avatar
Aint no "tho" about it. 150k old transmission, and pennzoil synchromesh made it feel almost new again. (**** 5th gear....)
You're absolutely right about that. but 3.2 is for the tremec 3650 5 speed. I actually wasn't entirely sure if OP was referring to auto or manual.
2002 GT 5sp. 16x,xxx miles
Old 12-03-2014, 08:01 AM   #12
Manual or Automatic?
When I responded with the link on how to change the Transmission oil and the 3.2 quarts, that was for a manual transmission.
For an Auto, I'd have it done rather than try to do it myself.
Old 12-03-2014, 08:42 AM   #13
Boosted_3v's Avatar
So Pennzoil Synchromesh? Anyone else have that in there 05-10 5speed trannys?
Old 12-03-2014, 10:14 AM   #14
I had it in my 02-04 3650. Like I said, damn thing was ridiculously smooth.
Old 12-03-2014, 10:17 AM   #15
bucko's Avatar
Good point...depends on the tranny type.
Smell oil burning thru interior air vents after oil change dentman43 2011-2014 Mustang GT 7 10-27-2014 08:36 AM
First oil change what oil sinister 2011-2014 Mustang GT 48 08-18-2014 07:57 AM
Auto tranny VS. Manual tranny x2bittz Classic Mustangs 15 06-29-2013 07:07 PM
Oil, Oil Additives, Oil Filters, FACTS robb15033 General Mustang Discussion 2 08-02-2012 11:37 AM
v6 tranny to a v8 tranny 97V6stangct Pre-2005 V6 Mustang 4 02-04-2012 12:42 PM
09:20 AM
