Retrofitting headlights - Mustang Evolution
Old 11-30-2014, 02:30 PM   #1
Hey guys I'm retro fitting my headlights and I have the headlight apart and was wondering if anyone knows how to remove the reflective piece inside the headlight
Harp12 is offline   Reply With Quote
Old 12-02-2014, 09:08 AM   #2
Dago's Avatar
you just have to pull really hard, it's actually easier when they are warm
2006 GT, C&L RACER INTAKE, FRPP THROTTLE BODY, FRPP INTAKE MANIFOLD, FRPP HOTROD CAMS, FRPP SHORTY HEADERS, CUSTOM X PIPE, BORLA ATAK MUFFLERS, FRPP SPRINGS, BAMA TUNE, CERVINIS STALKER II HOOD, STREET SCENE GEN 1 FASCIA AND REAR VALANCE
Dago is offline   Reply With Quote
Old 12-03-2014, 06:42 AM   #3
Abominable Mustang
WhoDat's Avatar
Region: Alaska
You're just removing it to paint it correct? Because the reflector is what the projectors mount to.
2012 Kona Blue 3.7L V6:
Old 12-03-2014, 03:09 PM   #4
Yes I'm removing it to paint it
Old 12-03-2014, 03:22 PM   #5
Dago's Avatar
Are you using the screw in projector style? Or you are going to cut your reflector bowls?
Old 12-03-2014, 03:43 PM   #6
I'm using the morimoto mini h1 projector....so do you know how to take off the reflector piece?
Old 12-03-2014, 04:02 PM   #7
Dago's Avatar
Yes, when I did mine I pull them off when they were warm, if you have a heat gun warm them up and then just pull them, they are just pressed in.
Old 12-04-2014, 01:45 PM   #8
Abominable Mustang
WhoDat's Avatar
Region: Alaska
I just painted mine while it was still in the headlight. Just taped up what I didn't want to get painted.
Sent from the Death Star.
Old 12-05-2014, 09:54 PM   #9
Dago's Avatar
You should post some pics when you are done, I like the output of the projectors I have, they look good from an angle but from the front they kind of look small, they remind me of a shark's eyes
Old 12-05-2014, 10:27 PM   #10
Alright dago!!
Old 12-06-2014, 08:34 PM   #11
IIRC, Morimoto came out with projectors that literally just bolt into specific housings and I think the 05-09 lights are one of them. Maybe not... or you can just have HIDGUY do it for you but that's like $500. Honestly I don't get the HID craze. I fell for it myself but there are halogens out there that are damn close to as bright as an OEM HID and brighter than 75% of the aftermarket kits out there because said kits are garbage Chinese $30 kits or 6K+ or both. IMO, just throw a pair of OSRAM offroad bulbs in there and call it good. They'll be over 2,000 lumens which is about 75% as bright as a 4300K HID and brighter than a 6K HID.
Old 12-07-2014, 01:47 AM   #12
WhiteCali5oh's Avatar
Region: West Virgina
I had retrofitted morimoto minis and 6k morimotos in my 2012 cummins. They were an awesome setup and didn't blind people because they were in an actual hid housing.
WhiteCali5oh is offline   Reply With Quote
Old 12-07-2014, 09:45 AM   #13
You did it correctly. Thank you, you are a rare bird apparently... For everyone like you there are 4 ******bags running a $30 DDM kit in stock reflector housings.
Sent from my VS980 4G using Mustang Evolution mobile app
Old 12-07-2014, 10:43 AM   #14
I know. I hate when people do it that way. It blinds the **** out of other drivers.
Old 12-07-2014, 12:44 PM   #15
Travis238's Avatar
I would like to see some pic on how you are doing the conversions start to finish.
2005 Roush GT, Roush cai, BAMA 93r tune
Travis238 is offline   Reply With Quote
Old 12-07-2014, 01:36 PM   #16
There are a ton of youtube videos on how to bake open headlights and convert them. I still say its complete overkill. Those who have had a correctly setup quality halogen headlight will concur. There are halogen bulbs out there that are damn hear as bright as a HID with none of the expense of converting or having to deal with projectors or ballasts or anything.
Old 12-07-2014, 01:43 PM   #17
I agree with that to some extent. But the light isn't as focused and clear as a good quality set of projectors and a quality hid setup. You can also choose different colors such as if you lived in an area that rains 24/7 and is foggy you could choose 3000k for the yellow as it's the best for those conditions.
Old 12-07-2014, 01:48 PM   #18
I put Nokya Hyper Yellow fogs in my 98 just for that reason. Yeah they are coated yellow so the lumens are down, bug fogs don't need to be omfg bright. They were still pretty bright...
Yes the HIDs do focus a nice cutoff beam and are super bright... but I have not ever had an instance where I could not see just fine with a good halogen and that includes on a back country road at night in a SN95 car with 0 street lights and the moon hidden behind the clouds. That was with my HIR hi beams in my old 98 I just sold. I had HIDs in the projectors (hi beams were separate) but had I kept the car I probably would have pulled the HIDs out and put HIRs in the projectors too.
Old 12-07-2014, 01:49 PM   #19
I've tried the nokya lights. Mine always burned out in about 4 months. Quality was the issue I think because my truck was new and my friend has the same problem with the purple ones they sell
Old 12-07-2014, 01:50 PM   #20
Hmmm, they were fine 6 months later for me but I hardly ever turned them on. Only when I needed to. One could always just use a regular OEM fog bulb which will be the normal yellowish color and do just fine with that.
Or go with a yellow LED fog... I do NOT recommend putting a HID in a foglight even if you retrofit. The cutoff on a retrofitted one would be too damn low to be of any use and in a reflector housing you are going to be that guy who blinds everyone just like HIDs in reflector headlights.
Old 12-07-2014, 02:15 PM   #21
I had the whitish ones in my low beams and they were the ones that always burned out. I never had the fogs
Old 12-17-2014, 02:28 PM   #22
Dago's Avatar
You got to do the retrofit?
Old 01-22-2015, 06:19 PM   #23
does anyone want to see the final product??
Old 01-22-2015, 08:13 PM   #24
Dago's Avatar
Of course, we all do.
Old 01-22-2015, 08:30 PM   #25
Pictures will be uploaded tomorrow
Old 01-22-2015, 09:06 PM   #26
Dago's Avatar
Will be waiting for them, how you like the output?
Old 01-23-2015, 02:27 PM   #27
Haven't taken pictures busy with work and I love it!!! Great output
Old 01-25-2015, 11:28 AM   #28
hey guys made a new thread go check it out!!!!
Its called my RETROFIT Creation
Changing a 1986 Mustang headlights into looking like a 1987 mustang headlights? Rayman 1979-1995 Mustang GT 1 12-17-2011 03:49 PM
Clear Headlights? RedDragonV6 Mustang Audio & Video 10 04-01-2004 09:28 PM
headlights?? YELLOW> Fishers Stang Mustang Audio & Video 22 11-06-2003 01:16 PM
Projectors or CObra headlights? TheSarge Mustang Audio & Video 16 09-18-2003 09:41 PM
Legal Headlights DropTop_Stang Mustang Audio & Video 10 08-07-2003 09:18 AM
08:20 AM
