3v block questions - Mustang Evolution
Old 12-08-2014, 01:46 PM   #1
Boosted_3v's Avatar
3v block questions
Name:	ImageUploadedByMustang Evolution1418071537.061113.jpg
This 3v block came out a 07 roush how can I go about cleaning it up? And anyone got a good ideas on forge internal kits? Wanna use it for a turbo build thanks!
Boosted_3v is offline   Reply With Quote
Old 12-09-2014, 04:15 AM   #2
Well, to clean up that rust you'll probably have to bore it out, if not resleeve. For internals, you can get a forged rotating assembly for stock displacement from MMR for about 1500. What do you know about the block? You might want to think about having it inspected for cracks and pinholes or you could find yourself spending a lot of money
Shuvool is offline   Reply With Quote
Old 12-09-2014, 05:01 AM   #3
which SOB let that gorgeous motor rust like that??
techlit is offline   Reply With Quote
Old 12-09-2014, 11:16 AM   #4
Boosted_3v's Avatar
Its for free guy had it sitting in the rain ): it's not blown or anything but if I clean cylinder walls won't I have to bore it out?
Old 12-10-2014, 05:26 AM   #5
Bennyhill's Avatar
You should re build it. I personally would have it bored 10 over, new Pistons and you have a "new" short block. Or disassemble hone the cylinder walls, new rings and re assemble. Either way the block should be inspected for cracks and defects.
Bennyhill is offline   Reply With Quote
Old 12-10-2014, 09:05 AM   #6
Boosted_3v's Avatar
If I bore it 10 over what pistons and rods do you recommend how far can the stock crank go or should I get a new one?
Old 12-10-2014, 06:08 PM   #7
Aggiesrok's Avatar
Don't stop short. Go forged the whole way. You don't want to be limited after all that.
Chevy runs deep, don't step in Chevy.
Old 12-10-2014, 06:29 PM   #8
Take it to a machine shop and have them look at it. I recently had a Teksid block bored and two of the cylinders wouldn't clean up at .020 so I had to replace two of the sleeves... And it didn't look anywhere near as bad as your block!
Old 12-10-2014, 09:31 PM   #9
Boosted_3v's Avatar
Forge the whole way is the plan been looking at mmd kits
Small block big block discussion @ work ReggStang 2005-2010 Mustang GT 6 07-15-2012 03:16 PM
small block/ long block blackGT91 1979-1995 Mustang GT 15 05-14-2012 09:21 PM
engine block color, valve covers and others questions lemons95 Pre-2005 V6 Mustang 3 03-13-2012 08:37 AM
5.0 block vs 4.6 block 98RedGT 1996-2004 Mustang GT 4 06-13-2011 12:03 PM
3.8 block/motor questions, among other things. NeedSomeMods Pre-2005 V6 Mustang 3 04-03-2011 06:13 AM
04:48 AM
