Crankcase vent - Mustang Evolution
Old 12-20-2014, 02:02 PM   #1
Boosted_3v's Avatar
Crankcase vent
Anyone ever use them? I had them on both passenger and driver side but I took off the oil cap and the oil looks milky is this bad?
Boosted_3v is offline   Reply With Quote
Old 12-20-2014, 07:00 PM   #2
S281's Avatar
If the oil is milky you've got a problem. If you just have a milky build up in the cap it's usually caused by short trips when the engine isn't hot for a long period of time. If your in a damp cold climate with 2 breathers I guess you could be drawing in moist air causing it too.
S281 is offline   Reply With Quote
Old 12-20-2014, 10:26 PM   #3
Boosted_3v's Avatar
Yea it's cold and foggy right now is that still bad?
Old 12-20-2014, 10:47 PM   #4
Travis238's Avatar
Is the oil on the dipstick milky or just on the oil cap.
2005 Roush GT, Roush cai, BAMA 93r tune
Travis238 is offline   Reply With Quote
Old 12-20-2014, 11:07 PM   #5
Boosted_3v's Avatar
Just oil cap
Old 12-20-2014, 11:10 PM   #6
Travis238's Avatar
Old 12-20-2014, 11:11 PM   #7
Travis238's Avatar
Then it is just a little condensation from short trips.
Old 12-21-2014, 01:12 AM   #8
Boosted_3v's Avatar
Is that bad something I should worry about??
Old 12-21-2014, 08:00 AM   #9
Cbird's Avatar
Region: Iowa
Crankcase vent
I'd put the stock pcv equipment back on if possible.
As for the milky yellow junk, no it's nothing to worry about but if you let it continue you will need to change the oil more often than normal.
Cbird is offline   Reply With Quote
Old 12-21-2014, 08:07 AM   #10
S281's Avatar
If you check it after a little longer trip you'll probably find the cap clean.
In theory with the breathers your drawing more moist air into the crankcase. This can reduce the life of your oil but if you're doing regular oil changes I wouldn't worry about it.
Crankcase vent GE3G 2011-2014 Mustang GT 24 05-09-2013 03:32 PM
Crankcase ventilation system The Puma 2011-2014 V6 Mustang 30 04-23-2013 05:17 AM
Crankcase Breather lBRAlD General Mustang Discussion 2 01-16-2013 10:47 AM
Crankcase Evacuation Pump Trojan Horse 1979-1995 Mustang GT 10 06-21-2012 06:14 AM
Time to Vent, I dont care if you read this Kiljosh The Bar 20 12-01-2005 05:10 PM
09:31 PM
