Radiator fan wont turn on - Mustang Evolution
Old 01-04-2015, 11:59 PM   #1
NDPX47's Avatar
Hey guys,
I have an 05 mustang gt, auto, 94k miles. The car overheated a couple of days ago and ive been tryin to figure out whats wrong with it.
I noticed the radiator fan was not on when it overheated and it doesnt come on. Checked fuse 40a and it did look slightly different than all the other fuses on there so i replaced it and so far the fan has not turned on still. I pulled the fan and it looks like the original ford fan, tried jumping it from the battery and it didnt start but I only hooked up 2 out of the 3 prongs that are on the connector.
Anybody that had this problem before and could chime in or anyone with knowledge on stuff like this that could help me out, it will be greatly appreciated!
NDPX47 is offline   Reply With Quote
Old 01-05-2015, 12:08 AM   #2
First I'd check to see if there is battery voltage going to the fans, check and see if it has a ground. There could be a short in the wiring.
Another possibility is the fan motors are bad.
Proud owner of:
1965 Chevrolet Impala SS pure original 327 300hp,360ftlbs Muncie 21 4spd, 12 bolt rear, mist blue white interior, 17in cragar thrust wheels, super 44 flow master mufflers. status: 98% restored
2008 Roush 427R #528 All stock except Roush billet grille, Roush CAI 460hp, 425ftlbs, 5spd vista blue white stipes black leather with blue inserts, stock Roush wheels and exhaust. Status: waiting for many many upgrades
70 Dodge Challenger T/A 340 Six Pack 290hp factory rated (bull****) 4spd hemi Orange black interior rallye wheels, T/A exhaust. status: restoration in progress
75 MGB convertible 1.8L 90hp, of pure evil, 4spd Mars red (VW color) black top black interior wire wheels. Status: restored and for sale
Hunting for a black 03 terminator 10th anniversary coupe
Old 01-05-2015, 12:19 AM   #3
NDPX47's Avatar
Check using a voltmeter right? Or am i wrong? What should it be reading?
Old 01-05-2015, 12:20 AM   #4
Do the cooling fans come on when the air conditioning is turned on?
Old 01-05-2015, 12:24 AM   #5
How hot did the engine get and how far did you drive it like that.
Proud owner of:
Old 01-05-2015, 12:31 AM   #6
NDPX47's Avatar
Cooling fans do not come on when ac is on max, it was a short trip i was driving it for about 20-30 minutes before i realized the needle was close to the H on the meter on the dash. Once i saw that i pulled over and shut it off and let it cool a little. I drove it a block down after 10 minutes to park it.
Old 01-05-2015, 12:37 AM   #7
gqsmash's Avatar
20-30 min of highway driving or city,stop and go? Were you stopped when you noticed it started to over heat is what I guess I should ask
gqsmash is offline   Reply With Quote
Old 01-05-2015, 12:39 AM   #8
NDPX47's Avatar
Most of the driving was on the highway... I noticed it was overheating when i was driving around the block trying to look for parking, i was visiting family.
Old 01-05-2015, 12:42 AM   #9
What I suggest is take it to your trusted auto tech or a ford dealer. They should have the proper tools to run diagnostics to make sure the engine is damaged
Proud owner of:
Old 01-05-2015, 12:49 AM   #10
You said the 40 amp fuse looked different. Was it blown? If so, check it again and see if it is blown again.
The two most likely suspects are the fans (or fan), or the Constant Control Relay Module.
Old 01-05-2015, 12:52 AM   #11
NDPX47's Avatar
The 40a fuse was a different color (copperish) and it looked like it had ridges. Will check the new fuse
Old 01-05-2015, 12:56 AM   #12
NDPX47's Avatar
Idk if u understand me, i have never seen a blown fuse so im not sure what its supposed to look like. I can attach a pic
Old 01-05-2015, 01:01 AM   #13
A blown fuse could look identical to a healthy fuse.
Proud owner of:
Old 01-05-2015, 01:08 AM   #14
Oh. Ok.
They come in different colors depending on the amperage rating of the fuse.
You notice that they are transparent and you can see the metal part that runs continuously through the fuse to both of the prongs. In the center of the fuse, it is thinner metal and that is the part that melts when the amperage exceeds the fuses maximum amperage rating. The metal part will be separated at that thin part and that is what is commonly referred to as a blown fuse.
Old 01-05-2015, 01:17 AM   #15
And Recon is correct. It can be sometimes difficult to tell if a fuse is blown or not. But since you replaced it with a known good fuse, you should make sure that it didn't blow the new one again, which can happen. If the fuses are continually blowing, it's almost certainly a defective fan. If not, it may be the CCRM but I would have someone knowledgeable diagnose it before throwing unnecessary parts at it.
Old 01-05-2015, 01:26 AM   #16
NDPX47's Avatar
Fuse looks complete, aside from some discoloration
Old 01-05-2015, 01:29 AM   #17
NDPX47's Avatar
Yeah thats what ill probably end up doing since i dont have the cash to buy all sorts of parts. Thanks for the help guys. Would it be safe to drive the car to work and back. Its a 10 minute drive and i would only be driving the car for that
Old 01-05-2015, 01:37 AM   #18
I think so. Just don't let it warm up. Start the engine and go. Keep an eye on the temp.
I had to drive my car ten miles one time with only about a half gallon of water in the radiator!
Good luck and keep us posted on what you find is wrong.
Post a pic of the fuse if you want. We'll try to determine if it is blown or not.
Old 01-05-2015, 01:48 AM   #19
NDPX47's Avatar
Thanks for the help guys! Ill post a pic of the fuse tomorow, its pretty late already.
Old 01-07-2015, 07:38 AM   #20
LeviG2010's Avatar
My 2010 GT overheated recently too. The plug for my rad fan had come loose and arced causing the fan to burn out as well as burn the connector. The fix was a new fan resistor and new plug for it. I upgraded the fan itself to a ford racing unit but the plug I had to cut off a wrecked car and splice in because none of the Ford dealers in my area could figure out a part number for said plug. They wanted 1500 for an entire new engine wiring harness. So I would check your connection and fan resistor. Could be the problem.
2010 Mustang GT steeda CAI, steeda underdrive pulleys, mangapack catback, kooks long tubes w/ hiflo cats, accel coils, FRPP throttle body
The driver doesn't pick the car. The car picks the driver.
LeviG2010 is offline   Reply With Quote
Old 01-07-2015, 03:42 PM   #21
NDPX47's Avatar
So check the plug and resistor? What should i be looking for?
I also got the ford racing fan, i put it in this morning but its still not working. Getting ready to take it to the shop since im getting pretty frustrated.
Can you post a pic of the resistor location?
Old 01-19-2015, 12:12 PM   #22
NDPX47's Avatar
It ended up being a sensor underneath the intake manifold. Shop replaced it for a new one and the fan worked.
New radiator fan wont turn on!!! Supe01stang 1996-2004 Mustang GT 13 08-11-2013 07:35 AM
Electric fan on a 5.0 or stock fan? Haav 1979-1995 Mustang GT 8 07-10-2012 07:34 PM
08:55 AM
