2010 GT, Speedometer Not Right, Warranty Fix? - Mustang Evolution
Old 01-05-2015, 01:07 PM   #1
Mgalli's Avatar
My 2010 Mustang GT's speedomoeter is acting up in the sense it does not reflect the correct speed. It's about 12 MPH fast. I've read through some threads and this seems more of an issue for 2005's. Does anyone know if I'm too far out of warranty period for Ford to cover this?
Thanks
Mgalli is offline   Reply With Quote
Old 01-05-2015, 05:47 PM   #2
How many miles on it?
Proud owner of:
1965 Chevrolet Impala SS pure original 327 300hp,360ftlbs Muncie 21 4spd, 12 bolt rear, mist blue white interior, 17in cragar thrust wheels, super 44 flow master mufflers. status: 98% restored
2008 Roush 427R #528 All stock except Roush billet grille, Roush CAI 460hp, 425ftlbs, 5spd vista blue white graphics black leather with blue inserts, stock Roush wheels and exhaust. Status: waiting for many many upgrades
70 Dodge Challenger T/A 340 Six Pack 290hp factory rated (bull****) 4spd hemi Orange black interior rallye wheels, T/A exhaust. status: restoration in progress
75 MGB convertible 1.8L 90hp, of pure evil, 4spd Mars red (VW color) black top black interior wire wheels. Status: restored and for sale
Hunting for a black 03 terminator 10th anniversary coupe
Old 01-05-2015, 06:52 PM   #3
Aggiesrok's Avatar
Did you get different wheels, tires or both?
Chevy runs deep, don't step in Chevy.
289 - Holley 4150 570cfm; Performer intake; mild cam; MSD HEI; 302 heads; Roller Tips; Hedman Tri-Y headers; H-pipe w/Flowmaster 40's; 9 in posi 3.50; 205/50-17F; 225/50-17R.
Old 01-06-2015, 06:21 AM   #4
Mgalli's Avatar
I'm at 63,700 miles and I did upgrade wheels/tires. I went from 18's to 19's. Tires were 245/45/18 however now on 245/45/19.
Old 01-06-2015, 08:07 AM   #5
Abominable Mustang
WhoDat's Avatar
Region: Alaska
That shouldn't be enough for a 12mph difference. Did you do a differential gear swap? Also, if you're car is tuned, they may have put the wrong gear ratio in the tune file.
2012 Kona Blue 3.7L V6:
Old 01-06-2015, 08:34 AM   #6
FangStang's Avatar
According to this website...
Tire Size Calculator
To have an equal size tire in a 19 inch you should be running a
245/40R19... they would be the same.
245/45R18= 756.3 revolutions/mile
245/40R19 = 755.3 revolutions/mile
245/45/R19=729 revolutions/mile
That equates to a 3.6% difference in revolutions between originals and the tires you have now... also, you don't mention at what speed the speedometer is off 12 mph...
However... less revolutions per mile should be making the speedo read slower... something strange going on here..
no other changes to the vehicle around the time you noticed the speedo error?
Grabber Orange 2007 GT 5-sp...Fang Performance Twister Special package. , 3.55:1 Limited Slip, Shaker 500, Predator tuned, C&L 95mm CAI, Borla X-pipe and cat-back exhaust. Hurst Comp Plus short throw shifter, 18x9 Black Bullitts with Nitto tires, "Stop the Hop" suspension package, suspension package, Koni Struts and shocks, SR lowering springs, SR double adjustable panhard bar, SR rear shock tower brace, 28200 miles
FangStang is offline   Reply With Quote
Old 01-06-2015, 08:37 AM   #7
Mgalli's Avatar
I would agree about the tire size not causing the 12 MPH variance and I haven't swapped out differential/gears - all powertrain is stock. My car is tuned by BAMA via American Muscle and I just called them and spoke to a guy named Justin. He spent some time going through the tune files and confirmed the rear end is set up correctly for 3.31:1 (stock), but adjusted the revs per mile from 753 to 729. He said that may help the problem. Once I get that in, I'll load it and see what happens and post a reply.
Thanks
Old 01-06-2015, 08:45 AM   #8
FangStang's Avatar
Thanks
It seems that that should solve the problem... correcting the speedo to the tire size... Good luck!
Old 01-06-2015, 02:29 PM   #9
Aggiesrok's Avatar
When correcting tire size, it's best to measure from the ground to the center of the wheel for a radius and then calculate the circumference and revs/mile. This takes into consideration the flat area where the tire meets the road.
Old 01-07-2015, 07:39 AM   #10
Mgalli's Avatar
Well, I loaded the Bama tune and I'm still 12 mph fast. There must be something deeper going on here. Does anybody know based on my year and miles on the car if I'm covered under warranty?
Sent from my SPH-L710 using Mustang Evolution mobile app
2010 GT Premium
Eibach ProSystem Plus, Airaid CAI, BBK Catted X Pipe, Flowmaster Outlaw Axlebacks, 20" Staggered Black DF5 Wheels (275/35/20 & 255/35/20), BAMA 93 Race Tune, Power Stop Z23 Evolution Sport Brake Rotor & Pad Kit, American Muscle Graphic Smoked Light Tint, SR Performance Strut Tower Brace, Raxiom Map LEDs
Old 01-07-2015, 06:55 PM   #11
sid719e's Avatar
The warranty is 3yrs/36,000 miles. Unless you purchased an extended warranty. Best thing to do is call a Ford dealership. They can answer those questions.
sid719e is offline   Reply With Quote
Speedometer not reading DutchManDann 1996-2004 Mustang GT 12 12-21-2013 09:25 PM
Speedometer MyColor lights will not turn on. Tyrannax General Mustang Discussion 4 09-15-2013 02:05 AM
Convertible roof damaged, $3000 to fix, yeah right? baldrik General Mustang Discussion 2 12-22-2011 02:52 AM
speedometer and gas gauge not working?? rob913 1979-1995 Mustang GT 0 07-03-2010 09:00 AM
Ford Mustang and cost to fix a right-side header? kang29 General Mustang Discussion 7 03-17-2010 04:47 PM
02:21 AM
