3v heads on a 03-04 cobra engine. - Mustang Evolution
Old 01-10-2015, 09:31 AM   #1
PonyOnTheBeach's Avatar
If I was to go a FI route with my car could I buy a termi block with everything but the heads and install my 3V heads on it, right? I've heard the 03-04 cobras can withstand 500 or 600whp, does that mean the same engine with my heads would be able to withstand the same amount of power? Finally would this be more cost effective than tearing apart my block and rebuilding it With forged internals? If I take the FI route I doubt I will want over 600go.
It's all about the Smiles Per Gallon
PonyOnTheBeach is offline   Reply With Quote
Old 01-10-2015, 04:57 PM   #2
Aggiesrok's Avatar
Why would you put 3v heads on a Cobra? They came with 4v heads.
Chevy runs deep, don't step in Chevy.
Old 01-10-2015, 05:02 PM   #3
natestang07's Avatar
And I was always under the impression that
4v heads> 3v heads
05 Gt Premium Performance White, flowmaster outlaws, Jlt Series 3, Bama 91r tune
Old 01-10-2015, 05:23 PM   #4
I think he wants to have the forged motor part of it and slap on the 3v heads so it drops right in.
It's easier just to forge your current motor. You will add a ton of weight with that cobra engine since it's an iron block.
Old 01-10-2015, 06:01 PM   #5
Yea that's what I was going for soccerluvr4. I didn't realise that the block was iron.
Old 01-10-2015, 06:04 PM   #6
Are there any other prebuilt 4.6 engines that I could just slap my heads on and install? I think there may be an aluminator block? Also is there a 4.6 with a higher compression than the 9.8:1 in our block?
Old 01-10-2015, 06:44 PM   #7
There are lots of places. Check out Cushman Motorsports. They have a range of shortblocks available.
I would recommend keeping your stock aluminum block though, its the late model WAP, its stronger than a Teskid block and 80 pounds lighter than an iron block.
You can get 13.0:1 compression or higher in the 4.6. Flat top pistons with 38cc heads will get you around 12.0:1 compression i believe, you can also get the block decked as well as the heads decked and pick up more compression that way. At that point you cannot run regular fuel anymore. You need E85 or race gas.
Old 01-10-2015, 09:32 PM   #8
Could I deck the block and heads without changing anything? Would it yield any gains? Also I don't have the experience or space to tear an engine completely apart. There is no way to replace the pistons without disassembling the engine, right? If not how much would it bee to have the engine disassembled and reassembled with new pistons?
Old 01-10-2015, 09:36 PM   #9
Decking the block and heads will increase compression. That's about it
Old 01-11-2015, 10:17 AM   #10
Fabman's Avatar
If you are doing a forged bottom end get a Stroker short block.
Ford racing has one complete for 4995.00.
Just bolt your top end on and go.
Tuned by AED
*694 RWHP/677 RWTQ* 10.22@136mph
Currently Assaulting California's Roadcourses
Fabman is offline   Reply With Quote
Old 01-11-2015, 10:47 AM   #11
How much would it be to have my engine disassembled, bored, and reassembled.
Old 01-11-2015, 10:47 AM   #12
Ford Racing also just started making a 5.3 short block. You get the longer stroke as well as the bigger bore.
Old 01-11-2015, 10:48 AM   #13
Could I use the 5.3 with my heads?
Old 01-11-2015, 12:50 PM   #14
Fabman's Avatar
Whaaaaat.....? I
wasn't informed if this....Is it an aluminum block?
JDM has a big inch mod but is a iron block....
Tuned by AED
Old 01-11-2015, 01:11 PM   #15
Originally Posted by Fabman View Post
Whaaaaat.....? I
I believe it uses the Boss Block. So Iron. If they made one with the aluminum i'd be all over it. Except at that point with TFS heads it'll be cheaper to put in a coyote lol.
Old 01-11-2015, 01:56 PM   #16
Fabman's Avatar
Yes, that's what JDM uses. I had a chance to go that way but the weight penalty was too much for me.
Tuned by AED
Old 01-11-2015, 02:39 PM   #17
Agreed. Even though I have an iron block right now. Whichever way I go with building the motor whether it is staying 2v or swapping to something else, it'll have an aluminum block. I'm considering a coyote since I won't do it for a few years and by then they will be easier to come by and don't need a whole lot of work to perform well.
Old 01-11-2015, 03:34 PM   #18
Fabman's Avatar
You can get a brand new crate engine w/ecu and harness for less than I have in my heads and short block. I have a $4000.00 set of CNC heads worked to the max and they only flow about as much as stock coyote heads.
Stock. Thats sickening.
Tuned by AED
Old 01-11-2015, 04:16 PM   #19
Yup. Can easily spend over $10k building the 4.6 with the best of the best stuff. Or i can just put in a coyote and forge it at the same time, replace valve springs and rev to 8k rpm.
Old 01-11-2015, 05:18 PM   #20
Fabman's Avatar
I wish I'd only spent 10 grand....coyote is definitely the way to go.
Tuned by AED
Old 01-11-2015, 05:19 PM   #21
Ok well what would be needed for me to switch over to a coyote?
Old 01-11-2015, 05:26 PM   #22
I almost don't even want to know how much you've spent on that car lol
Old 01-11-2015, 06:00 PM   #23
Fabman's Avatar
Let's just say I could have bought multiple GT 500's
Tuned by AED
Old 01-11-2015, 06:28 PM   #24
Damn........
Just buy a Lambo lmao
Old 01-11-2015, 06:45 PM   #25
Fabman's Avatar
Damn........
Lambos are gay. A mustang is a mans car.
Tuned by AED
Old 01-11-2015, 06:48 PM   #26
Idk, I have a big sweet spot for exotics lol
Old 01-12-2015, 10:03 AM   #27
Fabman's Avatar
A big sweaty spot for exotics...?
Tuned by AED
Old 01-12-2015, 10:08 AM   #28
The_Chech's Avatar
He means it gets him right in the feels when he looks at them
Oxford White Roush Stage 1 SN# 6925--SOLD but never forgotten!
Kona Blue GT premium - Slammed on BC's and BMR's full rear suspension
The_Chech is offline   Reply With Quote
Old 01-12-2015, 11:46 AM   #29
lol
Old 01-12-2015, 12:03 PM   #30
Fabman's Avatar
Tuned by AED
Pro comp heads vs gt 40p heads FordRacer_51 1979-1995 Mustang GT 25 10-11-2012 09:26 PM
4.2L heads? not as good as 3.8 split ports heads? lemons95 Pre-2005 V6 Mustang 0 02-20-2012 07:53 PM
E7 heads or Gt40 heads? Qwik Four Six 1979-1995 Mustang GT 18 10-29-2011 09:59 PM
FS: BV Heads, 173's,Cam, and Stock Heads petrey10 Mustang Parts for Sale and Wanted 4 06-26-2006 11:15 PM
Nice list of Engine Parts for V6 Mustangs: Heads, Cams, Intakes... Brent Mustang Parts for Sale and Wanted 22 04-21-2006 03:09 AM
10:22 PM
