2005 GT coupe top speed (stock) - Mustang Evolution
Old 01-15-2015, 01:49 PM   #1
Hello,
does anybody know the top speed of a pure stock 2005 GT coupe?
original and with the speed limiter removed?
Viking05 is offline   Reply With Quote
Old 01-15-2015, 02:38 PM   #2
natestang07's Avatar
I think it is 125ish with the governor.
05 Gt Premium Performance White, flowmaster outlaws, Jlt Series 3, Bama 91r tune
Old 01-15-2015, 03:11 PM   #3
Mark221's Avatar
I believe the speed limiter was set at 155 from the factory
Mark221 is offline   Reply With Quote
Old 01-15-2015, 03:13 PM   #4
^ doubt it
Old 01-15-2015, 03:30 PM   #5
Zcarmack16's Avatar
Can a governor be taken off or changed?
Zcarmack16 is offline   Reply With Quote
Old 01-15-2015, 03:31 PM   #6
Yes with an aftermarket tune. The two piece drive shaft is weak from 125+ so that is something to consider
Old 01-15-2015, 04:44 PM   #7
PonyOnTheBeach's Avatar
It's 143 from the factory. But your going to need several miles to reach it
It's all about the Smiles Per Gallon
PonyOnTheBeach is offline   Reply With Quote
Old 01-15-2015, 04:46 PM   #8
From my experience you start running out of steam around 125
Old 01-15-2015, 05:53 PM   #9
Mark221's Avatar
Not my experience
Old 01-15-2015, 05:55 PM   #10
Originally Posted by Mark221 View Post
Not my experience
Depends on how you describe "running out of steam". Remember what one person thinks is fast another might think is completely slow. Unless your motor has more than just bolt ons you will probably won't pull hard after 130. Also depends on gearing.
Old 01-15-2015, 07:41 PM   #11
Does anybody know the top speed of a car with 4.10 gears? I know theoretically it would be lower, but wouldn't the car be able to overcome the wind resistance easier?
Old 01-16-2015, 03:35 PM   #12
makes perfect sense (but i don't need miles to reach it)
because on the german autobahn i'm always really fast on 200+ kmh but around 143mph (145mph in my case) it's like i can't go any faster. so this is probably where the speed governor kicks in
Old 03-08-2015, 01:30 PM   #13
I found out when the limiter kicks in, i could feel it at 238 kmh (148mph)
but it was going downwards, i'm not sure if i would have been able to reach that speed on a flat part
Old 03-08-2015, 03:01 PM   #14
Well, my 08 Roush has a limiter at 142mph (speedo ends at 144) , I've gotten it to 140, before I let off. But it was pulling all the way...
Adventure till you drop
Old 03-21-2015, 04:53 AM   #15
I also live in Germany and drive my stock 2007 Mustang GT everyday on unrestricted portions of the Autobahn. The governor restriction does kick in at around 144-143 MPH, but more importantly, the stock car isn't really designed to travel this fast. You will notice that even in calm weather, the hood lifts up and bows at high speeds. A clear gap from the up-force is visible that shifts from side to side and creates a gap of much as 1/3 of an inch from the flush position. The front end starts to feel much lighter at over 130 MPH.
I generally cruise at 110 to 115 MPH. This is plenty fast and until I make some modifications, I'm not as nervous about eating my unpinned hood.
chappy1739 is offline   Reply With Quote
Old 03-21-2015, 10:15 AM   #16
509pony's Avatar
So how good should i expect to do at the track with a pretty stock car? Is it worth it to take it out and is it safe for the car ? Right now I have a full exhaust system with long tube headers, sway bars adjustable sway bar links, shocks and struts and springs. And ill through a tune on it before race day and possibly some 4:10 gears
Sent from my SGH-T999L using Mustang Evolution mobile app
509pony is offline   Reply With Quote
Old 03-21-2015, 11:19 AM   #17
Like a circuit or a drag strip?
It's all about the smiles per gallon
Old 03-21-2015, 11:24 AM   #18
By all means if you are wanting to race your mustang, who am I to say otherwise. I was simply making an observation that at 140 MPH + on the autobahn in my stock 2007 GT, 5 speed with 3.55 gears, 34k miles felt pretty unstable . I am also pretty sure that in most auto cross situations a stock mustang would need one hell of a straightaway for this to even matter. My car has good tires and a fresh alignment. Your car sounds like is most likely lowered an inch or more and has a totally different handling package. I just purchased the car, but this is my 5th Mustang. People race these things all the time and I am certain that a modified mustang set up for track racing can go faster than I probably want to go. I had never considered installing hood pins. The stationary alignment and fit of the hood seems just fine. My hood wobbles quite a bit at speed.
I plan to perform some similar modifications to what you mentioned. My car is a blast to drive and hopefully with little time, work, advice and money it will improve. As for right now, an M6 on the autobahn it is not. The fun factor for the money while driving in Germany is fantastic.
Good luck on the track.
2007 GT 5 Speed, windevil blue.
Old 03-21-2015, 11:52 AM   #19
509pony's Avatar
Yea I will be at a track. I hope I can hold my own lol
Old 03-22-2015, 10:57 AM   #20
Gil_T2's Avatar
Your top speed has very little to do with your performance in the 1/4 mile. Your gearing, tire dia, and the rpm that your can launch at and cross the finish at will be the deciding factors.
BBK LT's, Catted Xpipe, Sniper tune, UDP's GT500 TB, Ford Racing CAI, CM delete, 4.10, TR6060, 1 piece DS
Gil_T2 is offline   Reply With Quote
Old 03-23-2015, 01:18 PM   #21
I was on the autobahn again the other day, and as soon as i'm on it i just floor the pedal and it sometimes hit's the rev limiter if my automatic won't shift up fast enough
is this very bad for my mustang?
Old 03-31-2015, 06:09 AM   #22
irishn8's Avatar
Not really, rev limiter is there to prevent damage.
Old 03-31-2015, 10:37 AM   #23
okey I wanted to change the automatic transmission oil, but my garage told my it's not necessary have 47'000 miles on it.
At least i got an oil change since at least 7000miles, how often do you change your oil?
Old 03-31-2015, 07:59 PM   #24
irishn8's Avatar
Ever few years, not that it has to be done that often, i just do.
Old 04-07-2015, 05:41 PM   #25
The 5r55 trans you have actually should be done fairly often. They have longevity issues.
Old 04-14-2015, 01:32 PM   #26
Is the 5r55 the one who's in my stang? (2005 GT)
have now 50k miles on it, and never changed. my garaged asked ford and they said it doesn't need a change now
Old 04-14-2015, 02:58 PM   #27
If you have a automatic yes, if you have a manual it's a Tremec 3650
Old 04-14-2015, 05:00 PM   #28
They're full of ****.
Old 04-14-2015, 05:03 PM   #29
Scotty the 5r55s is a very low maintenance and stout transmission. Everybody knows that....
Old 04-14-2015, 07:41 PM   #30
Lol riiiiiiiiiiiiiiiiiiiiiiiiighttt....
The 5R55 should be done every 30k. They have issues with material in the internals actually coming apart and floating around in the fluid, over time this builds up. The 4R75w they replaced and the 6R80 that replaced them are both badass transmissions, for some reason the 5R is bleh.
Old 04-14-2015, 08:08 PM   #31
And the servo bores wearing grooves in the casing. Mine on my v6 crapped out at 100k with being serviced at 80k when I got it and once before sometime
Old 04-15-2015, 05:52 AM   #32
Yeah even with my bad knee, I would never buy anything with a 5R55 honestly... At least the 05-10 Mustangs aren't like the Lincoln LS with the pretty much all plastic 3.9L V8 and the 5R trans. Plastic parts start warping at like 30k miles and then transmission issues start happening if they aren't serviced like... every other oil change and even then.
Old 04-15-2015, 06:58 PM   #33
corey herron's Avatar
ive had my 06 up close to 160 but that's with aftermarket tune and some other bolt ons, may not believe me but I passed the last line on my speedo lol
New found love... the 06 GT
corey herron is offline   Reply With Quote
Old 04-15-2015, 07:01 PM   #34
How did it feel? Was it floaty?
Old 04-15-2015, 07:18 PM   #35
yeah it was really floaty, the long roads in the deserts of California gives you the opportunities to get on it every once in a while lol doubt I will even get close to that again because I went with the 373 gears and it doesn't seem to pull enough on the top end anymore
« WOT box? | Bama »
Stock, manual trans top speed? Caveman681 1979-1995 Mustang GT 11 10-06-2012 02:38 PM
Whats looks better a 1966 mustang coupe, or a 1967 mustang coupe? Carmi Classic Mustangs 3 12-17-2011 02:51 AM
89 mustang 5.0 gt 5 speed or 1993 240sx coupe 5 speed? Which car would you rather own? wendell General Mustang Discussion 5 03-17-2010 12:36 PM
1981 coupe t-top ndelong 1979-1995 Mustang GT 0 01-17-2009 12:52 PM
Fiberglass pieces for '66 coupe and '68 coupe..where to buy? MustangMatt Mustang Audio & Video 2 01-19-2005 09:14 PM
09:49 AM
