Power with engine - Mustang Evolution
Old 01-15-2015, 02:25 PM   #1
wiatt93's Avatar
Power with engine
Looking on here people are saying the 4.6 can only handle around 450hp. I'd like to get around the 600 range with a supercharger. In order for my engine to handle that what all would have to be done? Or would it be cheaper to do a coyote swap and supercharge it? Also a side question if I were to get the ford racing intake manifold and then buy a supercharger does that get rid of the intake manifold or would that stay on the car?
wiatt93 is offline   Reply With Quote
Old 01-15-2015, 02:28 PM   #2
For the price of a forged motor and supercharger you can swap in a coyote. That's what I would do
Old 01-15-2015, 03:16 PM   #3
natestang07's Avatar
Depends on what kind of a supercharger you get as far as the manifold is concerned. But fiscally swapping the coyote is a better choice
05 Gt Premium Performance White, flowmaster outlaws, Jlt Series 3, Bama 91r tune
Old 01-15-2015, 03:43 PM   #4
wiatt93's Avatar
I think since I've almost bought all bolt ons I'm just going to finish putting them on run it for awhile and save up for the swap.
Old 01-15-2015, 04:47 PM   #5
PonyOnTheBeach's Avatar
What's the average cost of a coyote swap?
It's all about the Smiles Per Gallon
PonyOnTheBeach is offline   Reply With Quote
Old 01-15-2015, 04:48 PM   #6
wiatt93's Avatar
I know for the engine it's around 6,000 as far as anything else you'd need I'm not sure.
Old 01-15-2015, 04:54 PM   #7
Its getting cheaper. A lot of parts you can find used. Especially the motor, those are becoming more and more common nowadays. Then there are the parts and such like the control pack, the exhaust, not sure about your car but with my 01 i would need an accessory drive kit to maintain my hydraulic steering set up (05+ uses electric steering i believe, so not sure what you would have to change, if anything). Transmission should bolt up since the bolt pattern is the same for all mod motors. Might need a Tubular K member.
It should be easier in a 05-09 than it should in the 01. Excluding the engine you are looking at around $4k in parts i believe.
Old 01-17-2015, 10:44 PM   #8
08Mustang's Avatar
05-09 still used hydraulic....electric was started in 2010 or 2011
08Mustang is offline   Reply With Quote
Old 01-17-2015, 11:15 PM   #9
Ok then the kit will be needed to keep the hydraulic set up.
Old 01-18-2015, 11:13 AM   #10
jellyroll's Avatar
Power with engine
Take a look a Ford Racing's stroker blocks. I just saw that they now have a new 5.3l built off of the 4.6l block. They already have the 5.0l stroker block which was over 450hp NA with their 3v heads and intake. In my opinion a much more expensive route, but it is a much better foundation to build up more power with.
2008 GT/CS - {SLP Loudmouth Axle Back Exhaust- SR Strut Tower Brace - Raxiom Sequential Tail Light Kit - C&L Street CAI - Bama Tune - FRPP Lowering Springs - FRPP Rear Sway Bar - FRPP Struts & Shocks - BMR TCA032 LCAs}
jellyroll is offline   Reply With Quote
Old 01-18-2015, 09:10 PM   #11
Caster Troy's Avatar
Region: Hawaii
You will be safe on the 4.6 up to 490 which is plenty fast if you set the rest of the car up right.
Caster Troy is offline   Reply With Quote
pure engine or turbo power? morthis32 Pre-2005 V6 Mustang 73 08-31-2012 10:48 PM
What's the biggest/most power full engine i can put on a 1964 1/2 mustang convertible? yitzchak8 Classic Mustangs 7 08-26-2009 08:53 AM
I have a 1999 mustang GT what would be a good engine swap for more power? or should i just mod mine? jonni 1996-2004 Mustang GT 9 08-22-2009 10:09 AM
Can anybody recommend a high horse power high torque engine? pueblo70 Classic Mustangs 4 08-21-2009 05:32 PM
It takes power to make power sporter 2005-2010 Mustang GT 3 05-13-2007 06:40 PM
05:15 AM
