New clutch then no pressure - Mustang Evolution
Old 01-19-2015, 04:37 AM   #1
Send a message via Skype™ to 10grabberblue
I have a 2010 gt I put in a new stage one clutch and slave cylinder day before thanks giving was driving good for like two weeks then was gone for three weeks I come back and drive for three days then all of a sudden my clutch starts loosing pressure while driving to where it was engaging at floorboard but cantbwait shift while engine is running but when off I can run through all gears I start it with clutch in and it lurches forward. I tried bleeding clutch every way and has done nothing if anything it just gets worse I replaced the clutch master cylinder hoping it was the issue but did nothing the first half off the travel has no pressure then the rest of the way has good pressure there are no leaks any where any one had similar issues I'm stumped I can't figure it out been working on it for a week now
Sent from my HTC6525LVW using Mustang Evolution mobile app
10grabberblue is offline   Reply With Quote
Old 01-19-2015, 10:42 AM   #2
Getn off's Avatar
Check the connection on ur slave. Might have a loose connection, or a cracked B nut. Look for traces of a fluid leak around everything, including internals.
Good luck.
Troy
Getn off is offline   Reply With Quote
Old 01-23-2015, 01:55 PM   #3
Sirtat's Avatar
or if you didn't do proper torque sequence on the clutch bolts I've seen the bolts back off before, if it was working perfectly then slowly started to fade the bolts could be backing off ! even the slightest amount will cause the exact problem your speaking of.. best of luck !
IBLT IT
2005 Promar Performance forged long block
Kenne Bell 2.8L LC mammoth supercherger
and and and I DRIVE IT LIKE I STOLE IT !!!!
http://www.youtube.com/watch?v=_K_QJ...ure=plcp<br />http://www.youtube.com/watch?v=NWfvYVYlfio&feature=plcp
Sirtat is offline   Reply With Quote
Old 01-23-2015, 02:34 PM   #4
Ok thanks I've replaced pretty much every thing in the clutch hydraulic system still isn't fixed to had it towed to a shop today
clutch clutch... clutch Butch SVT Mustang 4 06-29-2012 03:53 PM
Blinking Cel and then stopped blinking on my 2012 mustang gt with less then 400 miles sleeperstatus 2011-2014 Mustang GT 5 05-03-2012 06:16 PM
fuel line pressure vs rail pressure Sirtat 2005-2010 Mustang GT 2 01-10-2012 05:03 PM
ATTN: those with aftermarket clutch/pressure plate speedpenguin Pre-2005 V6 Mustang 0 04-20-2004 03:22 PM
Clutch sticking to Pressure Plate??? Rick0636 Pre-2005 V6 Mustang 5 11-08-2003 06:28 PM
12:04 AM
