Hurst Shifter in a 07 roush/ valve tap on start up - Mustang Evolution
Old 01-20-2015, 01:50 PM   #1
Joe Dirt 222's Avatar
Hello, I am currently looking at a 07 roush stage 3. I test drove the car. Is it normal to have left and right play in the shifter when it is in all gears? I had a short throw shifter in my 93 and I remember it was rock solid.
Also is it normal to have a slight valve tap on start up on the 4.6? Thanks
Joe Dirt 222 is offline   Reply With Quote
Old 01-20-2015, 03:11 PM   #2
irishn8's Avatar
The valve noise at startup could be a sticking lifter, it could be a really easy fix, you could also have to replace some parts. I would use this to get a really good deal on the car. Tell him its sticking lifters and will require them to be replaced.
Then after u get the car, hope a simple oil change will fix the issue.
Old 01-20-2015, 05:04 PM   #3
as soon as the motor warmed up the tick went away within a few min. I have searched the web and so far it seems like the tick is normal on start up on the 4.6
Old 01-20-2015, 05:09 PM   #4
Mark221's Avatar
pretty much. as far as the shifter I have a Hurst an it does have a little play side to side but its not excessive. It could be worn out but its an easy fix so if you get a good deal just replace the shifter.
Mark221 is offline   Reply With Quote
Old 01-21-2015, 05:43 PM   #5
irishn8's Avatar
My 4.6l doesnt. My v6 does once in a while but it has over 200k miles.
Old 01-21-2015, 06:05 PM   #6
What's the mileage? Plus if the owner drove the car like an idiot plays a lot in the condition of the car. I have a 08 Roush 427R with none of these issues. the car was probably driven like a race car all the time. Hammering on the car will cause some issues. Something you might want to have checked is the supercharger; the Roush m90 is known to leak.
Excuse my naivety. I was born at a very early age.
For Sale: FOR SALE: Hurst Black Shift Ball / No Hurst Script MELLOWYELLOW06 Mustang Parts for Sale and Wanted 0 01-30-2014 07:13 PM
Hurst shifter 50$ plus your stock shifter BaSohol Mustang Parts for Sale and Wanted 7 05-05-2012 07:52 AM
shifter linkage on a toploader with hurst shifter gardgriff24 Classic Mustangs 7 03-02-2009 10:34 PM
95 Valve Tap HiDecibelPny Pre-2005 V6 Mustang 0 01-16-2008 05:00 PM
valve tap rick or corey STEVE The Bar 27 08-02-2005 09:00 PM
12:04 AM
