Right plugs for a 09? - Mustang Evolution
Old 01-22-2015, 09:52 PM   #1
Cbird's Avatar
Region: Iowa
As expected, when searching "spark plugs" in the 05-09 section you will find topics on the two piece plugs and their removal on the older 3 valves.
Finally getting around to the coyote swap and am gonna tune up the 3v to aid in the sell once I'm done.
Would like to know if these are the right plugs and if anti-seize does go on the threads of these.
Name:	ImageUploadedByMustang Evolution1421988583.961255.jpg
Cbird is offline   Reply With Quote
Old 01-23-2015, 10:24 AM   #2
Cbird's Avatar
Region: Iowa
Welp, it worked. Didn't use anti-seize because the motor craft plugs use a nickel coating on the threads and doesn't require it.
I forgot to blow out 2 of the spark plug wells with my air compressor though because I was in the groove... Opps. Hopefully this procedure is just a formality and doesn't come back to bite me.. I can't imagine a little dirt and debris hurting the motor too bad since it should blow away after the first couple strokes... Right? :p
Problem with gt40p spark plugs want some good spark plugs but most wont fit?? Justbust1n 1979-1995 Mustang GT 6 03-01-2011 03:20 PM
right place at the right time with a camera (2 owned pics) fast64 The Bar 8 05-12-2004 10:20 PM
I got your 5.0 right here. Dom The Bar 1 11-15-2003 03:03 PM
this aint right.... fast64 The Bar 41 08-19-2003 11:09 PM
ECU code FA23...sound right? MUSTANGJUNKY420 Pre-2005 V6 Mustang 6 08-11-2003 04:35 PM
03:40 PM
