Camber Bolts - Mustang Evolution
Old 01-23-2015, 10:00 AM   #1
PonyOnTheBeach's Avatar
Camber Bolts
So I lowered my car and I could visibly see that the camber on my car was off, so I took it in to get an alignment. It turns out that I have 2.4 degrees on one side and 1.8 on the other. This is after the mechanic tried to pull out as much camber as possible. Since my car is a daily driver and is never tracked or autocrossed I would like to pull out some of the camber. Unfortunately I'm a college student and don't have the money to spend on camber plates, so would camber bolts work? If I installed camber bolts, would I have to be careful with my car? I've heard that the are somewhat fragile.
PonyOnTheBeach is offline   Reply With Quote
Old 01-23-2015, 10:06 AM   #2
Aggiesrok's Avatar
I haven't heard that they were fragile. But the bolts have limitations for how much they can be adjusted. The plates have a lot more adjustment in them and are probably a little more accurate.
How much is your car lowered? Are your numbers after the mechanic adjusted as much as possible or was that before he messed with it?
Old 01-23-2015, 10:07 AM   #3
The numbers are from afterwards. I'm lowered about 2 inches.
Sent from my LG-D800 using Mustang Evolution mobile app
Old 01-23-2015, 10:11 AM   #4
Aggiesrok's Avatar
Camber bolts are supposed to be good for +/- 1.75 degrees. 2 inches is a pretty good drop, probably need plates, not all plates have the same adjustment. Did you install an adjustable panhard bar? You will need one to adjust your rear axle, it's not centered anymore after a 2 inch drop.
Old 01-23-2015, 10:15 AM   #5
I would still like to have roughly 1 degree of camber, so I could just use the camber bolts right? I was just mainly worried about the durability of camber bolts.
Old 01-23-2015, 10:28 AM   #6
Aggiesrok's Avatar
Not to say people haven't broken them, but I haven't heard anyone with that problem. But it's a daily driver, so you're not racing. Track racing would put a ton of stress on camber bolts.
It would be a lot better than what you have now, until you could spend the cash on plates.
Old 01-23-2015, 10:46 AM   #7
I also don't have a panhard bar, like you mentioned before, I haven't been able to tell a difference and my thrust angle was on off by a tenth of a degree, so do I still need to worry about it?
Old 01-23-2015, 12:29 PM   #8
Aggiesrok's Avatar
The difference is the distance from the tire to the fender will be different on the rears. The stock panhard bar is not adjustable, so as you lower the car, it pushes the entire axle towards the drivers side. It will affect handling.
Do you still have stock LCA's in the rear? With a 2" drop, you would need adjustable ones or relocation brackets. If you have stock, getting aftermarket makes a huge difference in wheel hop and traction. If you get aftermarket, get adjustable ones since you're lowered.
If you just lowered it for aesthetics and it's DD only, you may not notice too much. But all those changes alter the geometry of the rear end and hurt handling and potentially tire wear.
Old 01-23-2015, 01:38 PM   #9
gqsmash's Avatar
I've been running the bolts for 25k+ miles...so far no issues with a 1.5in drop. Only racing it's seen is straight line
gqsmash is offline   Reply With Quote
Old 01-23-2015, 02:02 PM   #10
I just picked up two camber bolts from O'Reilly. They came with a lifetime warranty so if they brake It should be covered. But after talking to you guys I'm not worried about it
It's all about the smiles per gallon
Old 01-23-2015, 08:49 PM   #11
Aggiesrok's Avatar
Cool. Sounds good.
Chevy runs deep, don't step in Chevy.
Old 01-24-2015, 09:05 AM   #12
08Mustang's Avatar
I used camber bolts when I installed my SR springs back in September and haven't had any issues at all. Just be sure to the alignment shop torqued them all the way down or else you'll have an awful clunk when you hit the brakes and the weight transfers. Believe me I know lol, other than that zero issues out of mine!
08Mustang is offline   Reply With Quote
Old 01-26-2015, 04:44 PM   #13
I got the bolts installed and had another alignment done. Everything worked out, thanks for your help guys.
Old 01-26-2015, 06:04 PM   #14
08Mustang's Avatar
Good to hear it!
bolts bolts bolts! bcosta56 1979-1995 Mustang GT 8 10-10-2012 03:08 PM
Camber bolts a good option? austinknoll Pre-2005 V6 Mustang 12 09-10-2012 06:34 PM
Caster Camber Plates or Camber Bolts OutlawGT 2005-2010 Mustang GT 18 04-05-2012 04:55 PM
Eibach camber bolts bullitt1075 General Mustang Discussion 2 11-29-2011 11:18 PM
Stage 8 bolts, but no bracket bolts? CreationNation 1979-1995 Mustang GT 1 04-13-2009 10:00 AM
03:12 PM
