Racing Stripe Removal / Hard Glue - Mustang Evolution
Old 01-25-2015, 04:13 AM   #1
Hellish Horse's Avatar
Hi all,
I recently bought an 08 GT. The previous owner put Racing Stripes on the car & did a real hack job at it. Splices, Wrinkles & Bubbles in the stripes so I removed them. I used a Heat Gun to remove the stripes which came off fairly easy in about an hours time.
But it left a Hard Glue Residue behind that I'm having a lot of trouble getting off. I've used Goo Gone, Goof Off, WD40, Rubbing alcohol & 3-M Adhesive Remover. It takes off a little bit but will not break down the hardened glue to remove it. I've also tried Maguire's Ultimate Compound with a D/A Buffer. That just made the whiteness go away. It left the Glue behind & made it shiny.
Anyone know how to get this Hard Glue to break down & turn gummy so I can get it off. I've been trying everyday for a week now & haven't found a solution short of getting the car repainted.
I'm posting 3 pics below so you can see exactly what I'm dealing with. Any suggestions are appreciated. THANKS !!!!!
Hellish Horse is offline   Reply With Quote
Old 01-25-2015, 04:14 AM   #2
Old 01-25-2015, 04:16 AM   #3
Old 01-25-2015, 04:17 AM   #4
Old 01-25-2015, 09:34 PM   #5
Scotty 1's Avatar
I think I would go to a couple different paint shops and get their opinion
2013 Roush Stage 3 #13-0970, Roush Phase 3 675 HP upgrade. Dynotech 3 1/2 inch Aluminum Driveshaft, Stifflers Driveshaft Safety Loop, JLT Oil Separator, Track Package, X Brace Rear Seat Delete, Roush 20" Hyper Black Wheels, Roush trunk tool kit
Scotty 1 is offline   Reply With Quote
Old 01-25-2015, 10:03 PM   #6
If its an actual residue left on the paint you just gotta keep using non paint damaging products to get it off. Might have to go at it a few times with a buffer.
What type of pad did you use with the DA? For really cutting it down i would go with a microfiber cutting pad. They do the work of a rotary buffer without the damaging heat of one.
Old 01-26-2015, 10:03 AM   #7
Medium strength laquer thinner, Try it in the door jamb first. I used it to take off dried adheisive that was on the clear coat. Nothing else would work and was told to try it and it works. Goof-off may work, it's simiar to laquar thinner and comes in a smaller container but more expensive.
biglou is offline   Reply With Quote
Old 02-11-2015, 12:14 PM   #8
KryptonKnight's Avatar
Go to the local sign shop and buy a bottle of spray on liquid vinyl remover. I used it and the vinyl pulled off easily. Go slowly and keep the vinyl as close to the body as you can while you pull it. I did mine in the winter in the garage but I think it would have been eve easier when warm.
CAI,6pt.Cage,FRPPSprings,Raptor,UDP,Hurst,SiliconeHoses,BossStrutBar,LoudMouths,Plenum,Cam,Brake,Battery,StrutCovers,FRPP PC.ValveCovers,Chin Spoiler,Hood Scoop&Pins,painted 10"Stripes & Pins,EleanorGrill,Chin Spoiler,"C" Scoop,1/4 Side Scoops,Rear Fascia,PJ Rear Louvers,Roush Skirts & Rear Wing,Triple Pod & Gauges,CF Dash,2010Projector lights,2014Taillights, Real Carbon Fiber full kit,19" 2014 GT rims.
KryptonKnight is offline   Reply With Quote
Window won't stay on track (What glue to use) Clean98 Gt 1996-2004 Mustang GT 2 11-16-2014 03:09 PM
Window glue anyone? Mathew r Wright 1996-2004 Mustang GT 3 09-26-2012 05:33 AM
to stripe or not to stripe mustangchassy Mustang Paint, Appearance & Detailing 25 06-12-2011 01:08 PM
Vinyl Stripe Removal obxdude018 2005-2010 V6 Mustang 2 04-11-2011 11:44 PM
Glue on lenses. Dom Mustang Audio & Video 8 01-31-2005 09:57 PM
» Members Mustangs
G.L.
joe89
98 GT
98RedGT
Add your Mustang
12:42 PM
