Fuel options - Mustang Evolution
Old 02-09-2015, 11:04 AM   #1
Boosted_3v's Avatar
Fuel options
Cab anyone point me in a good direction for a fuel pump for a turbo build not going to exceed 450 RWHP
Boosted_3v is offline   Reply With Quote
Old 02-11-2015, 04:14 PM   #2
Boosted_3v's Avatar
Anyone 😒
Old 02-12-2015, 02:23 AM   #3
How much are you looking to spend is always a good place to start
clinesr22 is offline   Reply With Quote
Old 02-12-2015, 04:56 PM   #4
Boosted_3v's Avatar
Don't matter just something to hold 450
Old 02-12-2015, 05:44 PM   #5
Aeromotive a1000 has plenty of bump for what you are trying to achieve. Supports up to 1000 hp so if you do want to increase the ponys you have the supply.
Old 02-12-2015, 06:01 PM   #6
Scott2's Avatar
Have you considered a factory solution from Ford Racing? GT500 dual pump system. My car is just starting to run out of fuel at 585RWHP in an auto through cats with these pumps.
Ford Racing High Performance Mustang Dual Fuel Pump Kit M-9407-GT05 (05-09 GT) - Free Shipping
Old 02-12-2015, 08:00 PM   #7
Not trying to argue here but if you would have gone with something like the aeromotive a1000 you wouldnt have a problem running out of fuel and its $50 less the the setup you got. Just the facts here
Old 02-12-2015, 08:11 PM   #8
Scott2's Avatar
Not trying to argue either but I did not know that an Aeromotive A1000 was an in tank pump. Does it work in a non return style fuel system or is it designed for a return style fuel system with a pressure regulator? Are you using a A1000 in your S197?
Old 02-12-2015, 09:08 PM   #9
Im not cause i dont have one the question was what fuel pump should be used to support 450 hp. Aeromotive is a reputable brand with quality parts.
Old 02-13-2015, 04:23 AM   #10
Scott2's Avatar
I certainly agree that "Aeromotive is a reputable brand with quality parts". I am using their #12301 Fuel Filter and #13101 Injected Bypass Fuel Pressure Regulator in my return style fuel system build.
However, I am still recommending the GT500 dual pump system as the best solution to support 450 RWHP as it is a drop in plug and play solution that only requires wiring the second FPDM. With a return style fuel system supported by an Aeromotive pump there is a great deal of additional work to be done and pieces to buy.
The first picture shows the underhood fuel lines for my return style system and the second one shows the Aeromotive Fuel Pressure Regulator.
Old 02-13-2015, 06:58 AM   #11
Boosted_3v's Avatar
Looking to stay below 500rwhp so any fuel set up that won't brake the bank is fine with me, already have 60lb injectors
Old 02-13-2015, 11:43 AM   #12
Originally Posted by Mustang96 View Post
nice video there dude, i know your close to the 909 so we gotta kick it some time rellik . your car sounds nice , my mom has a digicam that takes videos but doesnt have a microphone on it , i should check to see if it has a jack for a microphone, not too sure
i need to take some vids of my car
Wow absolutely beautiful set up. I am jealous.
Old 02-13-2015, 11:47 AM   #13
Ok i dont know how i did this but scott2 that was meant for you hahaha nice set up.
need help with custom fuel rails, fittings, fuel pressure gauge tire Pre-2005 V6 Mustang 2 07-13-2015 03:32 PM
Replacing stock fuel door with stock fuel door...help? MarshallYoung 2005-2010 V6 Mustang 13 07-23-2012 11:23 PM
should i have to change fuel.pump and fuel filter?? jmpark527 2005-2010 Mustang GT 11 11-11-2011 09:38 AM
Pruchased my Fuel Injectors and Fuel pump today Brent Pictures and Videos 36 12-14-2010 03:22 PM
19LB Fuel Injectors; 190-255LPH Walbro Fuel Pump Brent Mustang Parts for Sale and Wanted 5 05-11-2005 11:04 PM
04:20 PM
