Car won't start after Cam install - Mustang Evolution
Old 02-11-2015, 04:37 PM   #1
Region: Hawaii
Installed some Hot Rod racing cams and even after putting a Bama tune on the car it still won't turn over. I thought it might have been that my battery no longer had enough cranking amps but that wasn't it either. Anyone have any possible ideas?
Harbinger is offline   Reply With Quote
Old 02-11-2015, 04:50 PM   #2
natestang07's Avatar
Did you wedge the chain?
Old 02-11-2015, 04:52 PM   #3
Region: Hawaii
Yeah, when we installed we wedged the chain
Old 02-11-2015, 04:53 PM   #4
Might sound like a dumb question but did you remove the wedge?
Old 02-11-2015, 04:56 PM   #5
Region: Hawaii
Yeah we did
Old 02-11-2015, 04:59 PM   #6
Did you check all of the cops and plugs?
Old 02-11-2015, 05:00 PM   #7
Region: Hawaii
Yeah, everything is where it's supposed to be and secure. We went over everything twice just to be sure.
Old 02-11-2015, 05:01 PM   #8
Region: Hawaii
I think the chain may have shifted on the cam sprocket. It started once but died almost immediately
Old 02-11-2015, 05:03 PM   #9
When you say "Won't turn over", do you mean that the starter won't spin the engine? Or the engine spins but it won't start?
Old 02-11-2015, 05:05 PM   #10
Did you Mark the chain and sprocket with a marker??
Old 02-11-2015, 05:13 PM   #11
Boosted_3v's Avatar
Put the motor on TDC and then Try it
Boosted_3v is offline   Reply With Quote
Old 02-11-2015, 06:29 PM   #12
Region: Hawaii
1. Spins but won't start
2. Yes I did mark the chain and sprocket
3. How do I put it into TDC?
Old 02-11-2015, 06:53 PM   #13
You would be hearing some kind of strange noise if a cam jumped a tooth.
A quick test to determine whether the non-starting problem is caused by no spark or by no fuel, is to spray some starting fluid down the throttle body and see if it "pops". If it tries to start, then you are not getting fuel. If it doesn't try to start, then you aren't getting any spark for some reason.
I know that you have double and triple checked everything, but go back and take a look at every single electrical and vacuum connection that you had to take apart to do the cams. Sometimes they can look like they are plugged in completely but aren't.
Old 02-11-2015, 06:58 PM   #14
Terminator's Avatar
Yeah you must be forgetting some sort of plug even though not much is required removing just intake and the cam phaser solenoids, how did you determine its not he battery jump start? trying charging the battery for a little if thats the case
Terminator is offline   Reply With Quote
Old 02-11-2015, 07:26 PM   #15
Region: Hawaii
We determined it wasn't the battery after we swapped it for a new one
Old 02-12-2015, 08:27 AM   #16
Site Sponsor
Hey Harb,
Sorry to hear about the trouble you're having with the cams. Having done them in the past I know they're not as easy as changing a tire! This sounds like it could be a Strategy Read Difference. Can you get back into the stock tune, and use the tuner to read the strategy for the team at Bama? Once you have this shoot them a call so they can make sure that it matches and they can give you some other pointers as well!
Let me know if you have any questions in the meantime and I'm here to help.
Alex
Toll Free: 1-866-363-4591
Free Same-Day Shipping!
Old 02-12-2015, 02:17 PM   #17
Hellish Horse's Avatar
If it were an older car I'd think the distributor was turned 180 degrees. I'm not sure how it works with newer cars as of yet as I've only worked on pushrod motors. Is there anything similar to that which could cause the problem ? I just bought an 08 GT so I have to go buy me a Chilton's to figure out how these motors work. Can't do any upgrades till I do that.
Hellish Horse is offline   Reply With Quote
Thought I'd share pics of my successful Push-to-Start/Remote start install! Jordan.Cortina General Mustang Discussion 32 01-30-2015 09:29 AM
Won't start after hard run. LilValentine302 1979-1995 Mustang GT 2 03-07-2013 04:17 PM
Car wont start after audio install TAC911 Mustang Audio & Video 2 11-28-2010 04:01 PM
CAI Install, now car won't start Bstang03 Pre-2005 V6 Mustang 9 11-10-2009 09:10 AM
Car won't start V6STANG007 Pre-2005 V6 Mustang 31 12-07-2004 07:07 PM
07:07 PM
