Best Gears - Mustang Evolution
Old 02-16-2015, 09:44 AM   #1
509pony's Avatar
Best Gears
My rear differential has a small leak so im replacing the gasket and gears just curious on whats the best option in gears brand and the ratio this is my DD bit I will be running it at tge track a few times a yr
Sent from my SGH-T999L using Mustang Evolution mobile app
509pony is offline   Reply With Quote
Old 02-16-2015, 10:29 AM   #2
Cbird's Avatar
Region: Iowa
Ford racing gears are cheap and work fine.
Go 4.10. Anything less and you will regret it.
Cbird is offline   Reply With Quote
Old 02-16-2015, 10:49 AM   #3
509pony's Avatar
Yea I was debating between ford racing and motives
Old 02-16-2015, 11:33 AM   #4
Cbird's Avatar
Region: Iowa
I was too when I was looking at gears. All my research pointed to ford racing being a fine option, even though they are quite a bit cheaper.
50k on these gears and they are holding up just fine. I feel very confident recommending them to you
Old 02-16-2015, 03:55 PM   #5
08Mustang's Avatar
Just put Ford Racing 3.73 in my 08, honestly whenever you can afford a Ford Racing product then it's going to be a solid option!
08Mustang is offline   Reply With Quote
Old 02-16-2015, 04:58 PM   #6
509pony's Avatar
How do you lije the 3:73 ? I decided to go with ford racing now I cant decide 4:10 or 3:73
Old 02-16-2015, 09:56 PM   #7
08Mustang's Avatar
I like the 3.73's a lot. Definitely can feel the better acceleration...and with my auto I'm turning about 2k rpm at 60-65mph
Old 02-17-2015, 04:35 AM   #8
Enorym's Avatar
I've had motives break on me...I went with standard gear for my replacement. I read that standard makes oem gear sets for a lot of cars and trucks.
Enorym is offline   Reply With Quote
Difference between 2.3 rear axle gears and 5.0 rear axle gears 93mstnglx 2.3 Mustang 9 07-07-2013 06:12 PM
4:10 gears vs 4:30 gears SwatKatz901 1996-2004 Mustang GT 5 03-24-2012 04:17 PM
3:55 Gears vs 3:73 gears 06Blue 2005-2010 Mustang GT 19 01-04-2012 07:57 PM
NEED HELP WITH GEARS!! Motive 4.10 gears? Cant find ford racing? Camaro Eater Pre-2005 V6 Mustang 4 06-23-2010 11:57 AM
Factory Gears Vs. Racing Gears tire Pre-2005 V6 Mustang 0 07-21-2003 05:02 AM
10:42 PM
