02 sensor problems after header install - Mustang Evolution
Old 02-22-2015, 12:42 AM   #1
Jon Al's Avatar
After I had headers installed and a new tune my 02 sensors are all throwing codes. I checked the wiring and everything looks okay. Could it be that I just need to replace them?
Jon Al is offline   Reply With Quote
Old 02-22-2015, 12:43 AM   #2
Longtubes or shorties? And did you cut of the cats?
Adventure till you drop
Old 02-22-2015, 12:52 AM   #3
Jon Al's Avatar
Longtubes with a cat less h-pipe
Old 02-22-2015, 01:01 AM   #4
natestang07's Avatar
You need to turn off the rear ones. They are saying "hey dude your cats aren't doing crap"
Old 02-22-2015, 01:02 AM   #5
Jon Al's Avatar
Pretty sure the rear ones are off. Plus there are upstream ones throwing codes
Old 02-22-2015, 01:03 AM   #6
Do you have extensions? What code did you get exactly, something must not be connected well enough
Old 02-22-2015, 01:06 AM   #7
Jon Al's Avatar
P2198 I believe just off the top of my head
Old 02-22-2015, 01:08 AM   #8
Are you idling roughish?
Old 02-22-2015, 01:08 AM   #9
Jon Al's Avatar
P2198 I think it was
Old 02-22-2015, 01:10 AM   #10
Jon Al's Avatar
Double post. It at times idles rough. It seems once the engine warms up to a certain point is when it really gets bogged down. Then once it's warmed up it runs okay but I definitely need to fix it
Old 02-22-2015, 01:20 AM   #11
http://www.obd-codes.com/p2198
Give that a read
Old 02-22-2015, 01:28 AM   #12
Jon Al's Avatar
Haha I actually have read that already. It kinda just says it could be several different things.
Old 02-22-2015, 01:30 AM   #13
Reading on other forums suggests it could be a manifold leak
Old 02-22-2015, 01:31 AM   #14
I'd say you've got a header leaking...
Old 02-22-2015, 01:32 AM   #15
Beat you by 13 seconds
Old 02-22-2015, 01:35 AM   #16
Congratulations...
Old 02-22-2015, 01:36 AM   #17
Congratulations...
Hey, it is a proud moment for Nate.
Old 02-22-2015, 02:01 AM   #18
Jon Al's Avatar
I've checked several times and I don't think they are. I may just take it to the shop and blow my Tax return on it
Old 02-22-2015, 02:45 AM   #19
Hey that is what I just did my friend!
Old 02-22-2015, 09:06 PM   #20
I would of installed new upstream sensors and have the dynoshop fix the code issues in programming.
Old 02-22-2015, 09:29 PM   #21
Jon Al's Avatar
I might replace them and see what happens.
02 sensor problems after header install Jon Al General Mustang Discussion 0 02-20-2015 11:00 AM
Problems with tune after install mods (CAI, TB, Plenum, etc) reboot4ever 1996-2004 Mustang GT 9 10-11-2013 02:38 PM
crank angle sensor/camshaft position sensor instalation 1996v6stang Pre-2005 V6 Mustang 0 11-03-2011 06:57 PM
Header coating. Ceramic vs. Chrome/painted with header wrap wc3john The Bar 10 06-27-2011 10:20 AM
86 svo mustang header panel wanted header panel? wit 2.3 Mustang 1 08-21-2009 08:39 PM
09:04 PM
