06 Mustang GT One headlight dimmer than the other - Mustang Evolution
Old 02-23-2015, 09:50 PM   #1
MustangGTZXR's Avatar
Hey ladies and gents so I just bought my car and I'm noticing the driver side headlight is dimmer than the passenger side. I'm currently using stock bulbs and replaced them and still the same problem. Anyone else have this problem before. I'm gonna be changing them to 8000k hids will that fix it?
2006 Ford Mustang GT
MustangGTZXR is offline   Reply With Quote
Old 02-23-2015, 10:18 PM   #2
Cbird's Avatar
Region: Iowa
Have you checked the fuse? On a pervious vehicle of mine I had the same issue, one dim (almost not even visible) and one normal, and a fuse was the culprit.
If the fuse is fine and you have a volt meter I can walk you through the next steps of testing for either low voltage, high resistance, or a bad ground.
Happy hunting
Cbird is offline   Reply With Quote
Old 02-23-2015, 10:36 PM   #3
Oh ok I'll check the fuse thanks I'll keep you updated
Old 02-24-2015, 09:20 AM   #4
If the fuse is ok, Take your vehicle to advance auto parts and run a loaded and unloaded test on the alternator and battery on their multimeter (it's free!) If you notice more lights are dim, usually your alternaternator can't hold a load, (meaning when the lights are on, a/c is on, radio is on and ect. While the car is turned on and running and excellerating) anything above 13 and less than 15 volts is excellent....But if the fuse is good and the alternator is good just replace the bulb and see where it goes from there could be a sign it's time to get a new one.
tomf1tz is offline   Reply With Quote
Old 02-24-2015, 10:11 AM   #5
I'll try that I changed the bulbs once already and I got the matching pair but that didn't fix it. I've also read to check the ground wire for corrosion and clean it off with a wire brush. I'll try things today when I get home and see what happens
Old 02-24-2015, 10:31 AM   #6
Cbird's Avatar
Region: Iowa
Yes sir. That is the order of steps I would take also.
The ground for the headlights is on the passenger side of the engine bay just left (if looking into the engine bay from outside the car) of the coolant reservoir, If I remember correctly.
Is one CAI better than the other? 02 360R 1996-2004 Mustang GT 33 12-08-2014 08:16 AM
Wiring Reverse Glow Gauge Overlays To Stock Dimmer Switch On 93 93mstnglx Mustang Paint, Appearance & Detailing 0 02-02-2014 09:17 PM
Back exhaust pipes. One is lower than the other. JeffG 2011-2014 V6 Mustang 2 09-02-2013 11:22 AM
dimmer switch 99-04 Mustang Ajmt719 Pre-2005 V6 Mustang 7 06-14-2013 03:23 PM
Dashboard dimmer 12 volts? 2011 mustang gt 2011-2014 Mustang GT 0 09-22-2012 03:06 PM
03:22 AM
