Cushman Motorsports Stage 1 Cams - Mustang Evolution
Old 02-27-2015, 02:41 PM   #1
I decided to go with the Cushman Motorsports cams stage 1. I will have the cams installed and tuned on the 9th of March. I will report the results then.
05_stang is offline   Reply With Quote
Old 02-27-2015, 02:47 PM   #2
natestang07's Avatar
Were they nsr?
Old 02-27-2015, 03:04 PM   #3
Stage 1? Not much more aggressive than stock.
Old 02-27-2015, 03:04 PM   #4
I don't understand this stage 1 talk lol
Old 02-27-2015, 04:37 PM   #5
I guess we will see on the 9th of March.
Sent from my SAMSUNG-SM-G900A using Mustang Evolution mobile app
Old 02-28-2015, 01:07 PM   #6
I just got some FRPP Hot Rod Cams, I'm Going to try to do the install myself. Has anyone else done their own installation? Is it hard?
albieg25 is offline   Reply With Quote
Old 03-12-2015, 09:50 AM   #7
Car made 340hp and 326rwt with the Cushman Cams. Not bad hp numbers, because the clutch was slipping. New clutch is next. Any suggestions?
Old 03-12-2015, 04:08 PM   #8
Terminator's Avatar
I can say an install is easy but a friend tried doing the same an had a hard time
so dont attempt if your 2nd guessing on a install in the valve terrain
Terminator is offline   Reply With Quote
Old 03-15-2015, 07:08 AM   #9
What about doing the install without removing the roller followers?
Old 03-15-2015, 06:04 PM   #10
Just take the caps off carefully and make sure things don't move. Go slow, and take time. There are a couple videos on youtube of cam installs.
theonekyle is offline   Reply With Quote
Old 03-17-2015, 10:20 AM   #11
You don't need to take the followers off... get a chain tensioner tool for the timing chain and then remove the actuator leaving the chain on it. Make a mark just in case. Remove cam caps and then the cam. Put new can in torquing from middle to out
Sent from my LGMS323 using Mustang Evolution mobile app
Heuer is offline   Reply With Quote
Old 03-19-2015, 08:34 PM   #12
O5_stang what other mods do you have
sonicblewgt is offline   Reply With Quote
Old 03-19-2015, 08:50 PM   #13
Bama tunes, JLT 3 cai, pypes lt headers, o/r x pipe and the Cushman Cams.
Old 03-19-2015, 08:58 PM   #14
Long tube headers correct
Old 03-19-2015, 09:11 PM   #15
Correct. When the car made 340hp it was with a custom dyno tune.
Old 03-19-2015, 09:12 PM   #16
Oh I see alright then
Old 03-19-2015, 09:16 PM   #17
I have a guy in Charlotte NC that does all my tuning and does most of my installs. He will be putting 3.73 in my car in two weeks.
Old 03-19-2015, 09:38 PM   #18
I see well I plan on just redoing the insides of my engine to get alittle more power do you happen to have any suggestions
Old 03-20-2015, 04:33 PM   #19
That depends on what your goals are. Do you plan on go forced induction or stay naturally aspirated?
Old 03-20-2015, 05:20 PM   #20
Well I want to know na and forced induction and around how much u think it will run me for either
Old 03-21-2015, 06:44 AM   #21
If you go n/a you will need to go with a forged stroker motor. So companies sale them from $3500 - &7000 for a short block. You can put f/I on the car from $5000.00 to $7000 or more depending on what you want to spend. I'm going to go with a Whipple charge in the future.
Stage 3 Motorsports Srohda General Mustang Discussion 30 06-01-2013 04:59 PM
Lake cushman wa cruise photos gregtommy Pictures and Videos 9 09-06-2012 08:26 AM
Stage 3 Motorsports JasnTX 2011-2014 Mustang GT 7 06-22-2012 11:39 AM
Supersix Motorsports Stage 3 red_pony Pre-2005 V6 Mustang 8 12-27-2006 07:03 PM
01:36 AM
